abs light flashing
peganit
Michigan
I disconnected the front middle ABS sensor when I changed the radiator and THEN! I found out that was a bad thing to do.
How do I get the ABS light to stop flashing?!?!?!?!
Must mean air bag. Count the flashes when you power up the car. It should be a two digit code repeated a couple three times.
Diagnostic Trouble Code Table 1994
AIR BAG DIAGNOSTIC MONITOR DIAGNOSTIC TROUBLE CODE PRIORITY TABLE
Priority Code Component/Fault Description
Highest - No Air Bag Indicator - Inoperative Lamp Circuit or No Ignition
Voltage to Air Bag Diagnostic Monitor
Continuous Air Bag Indicator - Air Bag Diagnostic Monitor
Disconnected or Inoperative
12 Low Battery Voltage
13 Air Bag Circuit Shorted to Ground
14 Primary Crash Sensor Circuit Shorted to Ground
21 Safing Sensor Not Mounted to Vehicle Properly
22 Safing Sensor Output Shorted to Battery Voltage
23 Safing Sensor Circuit Input Feed/Return Circuit Open
24 Safing Sensor Output Feed/Return Circuit Open
32 Driver Side Air Bag Module High Resistance or Open
33 Passenger Side Air Bag Module High Resistance or Open
34 Driver Side Air Bag Module Circuit Low Resistance or Shorted
35 Passenger Side Air Bag Module Low Resistance or Shorted
42 Center Radiator Primary Crash Sensor Feed/Return Open
44 Center Cowl Primary Crash Sensor Not Mounted to Vehicle Properly
45 Center Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
51 Diagnostic Monitor Internal Thermal Fuse - Fuse Blown Due to
Intermittent Short to Ground
52 Backup Power Supply - Voltage Boost Fault
53 Primary Crash Sensor Circuits - Resistance to Ground or Air Bag
Diagnostic Monitor Failure
Lowest - Rapid Continuous Flashing of Air Bag Indicator (No DTC) All Primary
Crash Sensors Disconnected
peganit
Michigan
I had had a few.
:beer:
OK, more then a few. I'm surprised I did as well as I did.:partytime::)
The air bag light flashes 32. Where's the driver side module?
If it's under the driver side dash I know what happened.
Is the horn not working related to the air bag problem?
projectSHO89
SHOless In St L
St. Louis, MO
:beer:
Probably. The horn and the module in the steering wheel share common circuitry in the clockspring.
Steve
peganit
Michigan
yep
No cruise on mine either.
Why does my car have a clock spring. For the horn.
Where's the effin fuel pump ground? On a code 542, how likely is it that it's the ground?
peganit
Michigan
correction
you mean the motor stalled, which it has, many times. The car is an automatic.
So no issue with the fuel pump then?
