Doing Suspension, need parts list.
RiceeatingSHO
Travis R
Alabama
I have the struts and I am going to get Eibach springs and KYB Front/Rear strut mount kit from SHOsource. What else do I need while the suspension is apart? I am going t oput in my order tonight or tomorrow.
oldyak
memphis,tn
I would recommend all new bushings front and rear.
they are available through auto zone or RCM.
also anti sway bar bushings and endlinks.
This is only my opinion having a 1989 with 200,000 plus miles!
also might want to check inner and outer tie rod ends.
and look for leaks in steering rack.
do as much as you can as money permits...and you will have a really
tight SHO!
  • Like
Reactions: RCM
RiceeatingSHO
Travis R
Alabama
tight SHO!
Money is the biggie. Mine is an 89 with 186,*** miles...I know I needa new steering rack/pump but I just keep fluid in it.
itwonder
VA
For the struts, get new dust bellows, which also includes new bump stops in the kit. If money is tight, I don't know that I would go for new strut mounts unless you know the strut bearings are bad. I have yet to see any of the aftermarket ones that are as well made as the OEM Ford ones. The rear ones take less abuse than the front.
