any easy way
E1 v2
crash tested
holiday inn
any easy way to change the 7&8 coill,s with out takeing the manafold off
I see this is your first post.
You may have not seen this before -
- Firewall -
1, 2, 3, 4,
5, 6, 7, 8,
- Radiator -
Cylinder 7 and 8 are right up front, the two coils closest to the battery, under the appearance cover. You'll need a 10 mm deepwell socket with an extension to get the appearance cover and IMRC box loose, and a 8 mm socket for the coils.
15 minute job if you drag your heels.
NebraskaSHO
Harumph!
Omaha
These guys are right. 15 minute job.
Check out the Nebraska SHO chapter.
