Short Block
sablesho97
shoable
braintree
Hey, I finally got my short block today from ebay. It was like christmas all over again. Now just gotta finish the heads and i can assembly the thing finally.
ThatShoGuy
michigan
got mine coulpe weeks ago.. like christmas for me to... :angelnot::woohoo:
my heads are rebuilt.... so i should be good there.. i just got to get the cash up to buy the head gaskets and bolt and i can R&R the motor..
Don't forget the rear main seal. And there is an undrilled boss on the left side of the motor for a tranny bolt.
Undrilled boss w hi lite
Inkertinker
Well-Known Member
Charlack, MO
Thanks for the info on the hole that needs to be drilled. I had heard about main seal but not the missing hole.
FWIW I was eyeballing some Duratec head bolts this weekend. They are about 3/4" longer than the V8 bolts and come with a washer. Looks to me like you can just whack them off a bit and use them in the V8. Available at most parts stores.
Silvapain
Limestone, IL
someone posted on TCCA about the head bolts. From the pictures the ford head bolt have a longer shoulder on the v6 tec. on the after market ones i don't know.
The v6 bolts were also longer then the v8 bolts.
http://www.taurusclub.com/forum/index.php?showtopic=55275
Those were the exact bolts that Paul looked at - he was at my house last weekend. The Duratec bolts are ~1/2" longer, and that difference is entirely in the unthreaded shank; ie, the threaded length is identical between the two. I've looked closely at the two, and I'm going to thread the Duratec bolts higher up and see if that does the trick. IIRC, the thread is M10-1.25
sablesho97
shoable
braintree
Thanks for the info guys. Anyone know where to get some valve work done? I want someone who has worked one the sho heads before. Thanks for you time...
