code 214/528
voogru
Miami, FL
freaky code pops in on me, my engine runs good most of the time then all of the sudden it runs bad as if 3 cylinders took a vacation.
I wont be able to hold road speed without severe bucking, then all of the sudden it goes away.
this car has every sensor changed to new ones, this car really dont like me:nut:
SHOMON
95 MTX
MEDWAY MASS.
When you change it does oil leak out? If so you most likely need a cam seal. Bad seal= hot engine oil all over new sensor.
Storm-Chaser
Shit Louis
It may also be a harness short or bad terminal connector in the harness - which is shorting-out the camshaft sensor.
Since you've gone through three - have you tried the suspected bad sensors in another SHO to ensure they were bad?
