1993MTXSHO
Its a Taurus...
ok guys Iv done all I can think of to do on this, and really need some input. As some of you know I just swapped the engine on my atx (old engine ran fine just the bearings were on their way out) I got he new engine in and it fired right up, first turn of the key almost instantly. The only thing I did to the new engine was replace the crank sensor wp, and plugs and of course retimed it. I drove it home, then took the dash apart to replace the CE light (burned out, gee guess it got a lotta use haha). Low and behold once I drove the car the light turned on. It turns on a few minutes after driving, and turns off every time I turn the car off but always comes back on. I ran codes and got 172 176 542 543. I had a feeling I mighta smashed the front 02 sensor and that was why I was getting codes, so I replaced it with another used one. Same problem, then replaced it with another known good one, yet again same problem. I reset the computer and did everything again and got code 172 and 176 but the others were gone. Then I remembered I had to solder the wiring harness because it was cut from the yard. So I rechecked and made some of my solders better, but STILL have the light. The car runs ok and idles fine, but when I step on the gas it kinda shutters a little, not bad but I can feel it. Then I guess it resets to defaults or something and takes off like it did with the old motor. The only thing I haven’t done is replace the rear o2 but it was fine on the old engine and im only getting a code that is saying the front one is bad. Is there anyway to check to make sure my solders are good like stick a meter in the plug and see if it’s getting a certain voltage or something?
Heres the only thread that kinda helped me:
http://www.shoforum.com/showthread.php?t=83457&highlight=172+176
The car failed inspection (sticker expired in November) and If I don’t go back by end of Feb. they can revoke my registration.:thankyou:
