Fuel Light
qball305
1999 Gen III
New Jersey
When the fuel light comes on, about how much is still left in the tank? I don't want to have to find out the hard way.
wuzzzer
MN Moderator
St Cloud, Minnesota
Well, you could always wait for the light to come on and then find a gas station and drive around and around the block until your car runs out of gas. Then you'll know for sure. :)
shodoug
texas
Mine does not come on at the same fuel level all the time.
Also, my fuel gauge is not at all accurate under 1/4 of a tank.
When I first got the car, even though it was not accurate, it seemed like it would fluctuate around if there was fuel in the tank, and then stop fluctuating when it was really time to get to a gas station. Then, one night, it was still fluctuating pretty well when it died and I coasted into a gas station.
Resetting the trip odometer after every fillup works best for me.
You don't want to run it too far down, too often, The gas in the fuel tank helps to keep the fuel pump cool.
Best Regards,
Doug
Mr Anonymous
Tire Wall
St. Louis, MO
4 gallons is where it is supposed to come on, but every car is a little different and anywhere from 3 to 6 is where it will fire.
Once the fuel gets around 1/4 tank or so, you'll see the level seem to slowly increase when the car is on a downslope, and decrease on an upslope. The reading will lag due to the anti-slosh circuit which keeps the gauge from jumping around erratically.
Every SHO I've ever owned, one of the first things I do is pull the stupid bulb. If I can't keep track of my fuel level and mileage without a stupid light, I shouldn't be allowed to drive. :nut:
FWIW, I've found that the '98-'99 gauge senders are much more accurate across the entire range of the gauge than the '89-'97's.
E1 v2
crash tested
holiday inn
I've run 3 of mine dry just to see, and it seems around 60 miles was what I could get after the light came on.
NebraskaSHO
Harumph!
Omaha
I've run mine dry once and I think I got about 50-60 miles after the light came on. It comes on pretty early too.
hawkeye18
Sorta cares
Norfolk, VA
Can the 98-99 senders be used in a gen2? If it can, that's something I'd consider doing. I hate my sender with a passion. I get 100 miles at the 3/4 mark, then at the 1/2 mark I have 150. Every. Time. I'm used to it, but it's still aggravating.
Mr Anonymous
Tire Wall
St. Louis, MO
You'd have to get a 98-99 gas tank to fit since the Gen 3 fuel pumps & senders use a canister setup, but I think as long as you were able to get a tank to fit it should work OK. I've never tried fitting the tanks across gens, so I don't know if it's even possible.
naval-avi8or
Chesapeake, VA
Will not fit. GEN III tanks are slightly wider.
When the Gen2 was produced, Ford had a standing order that the light comes on at least 50 miles before empty...
I'm 72% sure on that one.
I get gas at the 3/4 mark. All my credit card is good for.... Soon will be at the 1/2 tank :(
