poly urathine
bubba
ATX Connoisseur
Fort Wayne, Indiana
Do they make poly urathine master set? I searched but came up with a noose egg. I'm Working on tighting up my ride.Thanks.
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
Poly needs to be greased, consistently in order to avoid the nasty squeaks.
TPR bushings are available at any parts stores that can get MOOG suspension components.
jedhead
westminster,ca
I only know of Delrin and Aluminum other than the stock rubber. Delrin you have to re-tighten every so often.
Bob
sdpatt
Sr. SHO Engr.
Dallas, TX
O'Reilly carries many of the Moog "upgrade" bushings in thermoplastic resin (TPR). I'm sure you can get them from RockAuto.com and other sources too. Look for the blue bushings. I have many on my SHO.
baySHO_510
**** It broke!!
Manteca & Oakland Ca.
polyurethane?....
Pic?
Thats what the previous (original owner) told me they were. He said poly-something maybe I missunderstood him, they're a white/tannish color. They are no where as stiff as the ASFBs but still better than stock... I'll take some pics of them and post them in the morning.
bubba
ATX Connoisseur
Fort Wayne, Indiana
Thanks man I will look for them in blue.
TankII
Bolton, CT
Quick side-note:
I just replaced the bushings on my SHO.
Last time i replaced them, I tightened the bushings with the car still on jacks. When the inside front tire unloaded, the car bobbled a bit. This time, I tightened them in the proper 'loaded' position - tires on the ground. What a difference! The suspension doesn't want to drop that inside front anymore and the bobble is gone!
Just anther tip.
TankII
