Marccus
What is the correct OEM part# or Motorcraft part# for a water pump for a 1989 SHO?
I ordered the Motorcraft part from Green Sales, they listed a part# on the invoice as: F4PZ8501A
The number stamped on the pump casting is: RF-E6AE-8505-AC
I checked with RockAuto catalog and spoke to them. RockAuto lists the following Motocraft part# for a 1989 SHO:
MOTORCRAFT Part # PW321 {#F4PZ8501A}
E6DZ-8501A O.E.M. NUMBER; E6AE-8505AC,AD O.E. CASTING NUMBER
The salesman said I had to check what OEM part# is listed for a water pump for my vehicle or check the number stamped on the casting for the pump installed in my car. If they match the part numbers listed above then this pump will fit.
I haven't checked the casting number since I am only buying the pump in case the one on the car fails (390,000 miles) and I don't know the OEM part#.
I guess I could crawl underneath the car and check the number on the casting.
But, the part does not look like the water pumps I've seen for Gen 1 SHO's when I've taken engines apart in junk yards. The impeller looks totally different.
Can anyone advise?
Thanks.
Can anyone advise?
Thanks.
