Trouble Codes
BIG K
I'll have a 7&7
Winnebago Co.
Hey Everyone........
It's the strange guy from Oshkosh seeking help. Wednesday I went to Auto Zone to have the check engine light checked out. 4 codes total........
176, 212, 214, 327. I changed the 02's that day. Scratch off 176.
Just an hour ago I went to Advance Auto Parts because the light came back on. 4 codes again....
335, 212, 214, 327....335 didn't show at Auto Zone. Scan tools different???
I have ID's for the codes just didn't feel like typing it all right now.
CHANGING THAT 2ND 02 SUCKED ROYALY!!!!! I'm sure everone knows:biggrin:
Keith How much $$$ are we talking here:nut:
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
is this a gen III or gen II?
its hard to tell... the O2s on my Gen II took me all but 10 minutes, including finding the tools and jacking the car
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
looks like you have a CKPS on its way out too... thats what 214 points to atleast... which could also cause 212, unless you had the spout pulled to try and pass emissions
BIG K
I'll have a 7&7
Winnebago Co.
No emissions in Winneseptic (Winnebago) County. I'll see what happens when I swap out the egr and get back to ya.
Thanks to dantheman68 for reply.
Kickinsho
SHO CRAZY
Sheboygan, Wisconsin
You probably already know this but make sure you disconnect the battery cables for at least 30 minutes after each "fix". You don't want to keep reading the same codes for no reason.
Been there way too many times with my '93 ATX
362104
DV8
43*46'30"N 88*26'41"W
I failed to do that when I changed the 02's, but the code did go away. I need to remember to do that in a couple days when I change the EGR. Thanks for the reminder:thumb: I just diconnect the Negative, not sure if it's necessary to do both. I haven't been doing much wreching on the Lightning lately.
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
The positive cable for sure needs to be disconnected, if not both.
It shouldn't matter, you're disconnecting the circuit by taking the negative off, removing power from the ECM.
The codes usually go away over time too, if you're doing it to check to see if the problem is fixed, I wouldn't check right after disconnecting power, because then you wont have any codes in memory either (essentially all it will show you is what sensors are out of their ranges i.e. unplugged or defective) i usually drive it for a day after resetting it and then check it
inverse1216
daytona beach, fl
you mean to tell me there is an autozone out there that has obd1 scan tool. the ones around me never seem to have the "adapter" to do obd1.
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
we have the tools, we just don't test them for you. since you can do them yourself with a paper clip, there is no need for us to do them.
welcome2daSHO
Crowderhead
Milwaukee, WI
so a tip for everyone on the o2 sensors. i took like a weekend to redo them when i realized i could drop the whole exhaust out. i had the car off all four and took a torch then impact wrech to the two bolts on the front header and two bolts on the back header, then around the third cat there was two rubber hanger i slipped off and since i had side exhaust everything came out super easy, slid out the exhaust on the floor next to me took the o2 sensors off and put the new ones on, was so much easier, then before i bolted everything back up i pluggged in thge new o2 sensors.
362104
DV8
I was at Sears one day and noticed they carry a tool for changing 02's. Will be buying it when the time comes again. Never had to mess with these before.
