weird stuff at full throttle
professorkaos93
rules the world
cinci.
so i thought my problem was my front motor mount, which was a little bit of it, but when i am at full throttle my car acts like it is missing until i back out of it and then it accelerates fine. any ideas? the motor has about 65 to 70K miles on it. so could it be time for a tune-up?
hawkeye18
Sorta cares
Norfolk, VA
try a new throttle sensor. It may not be reading correctly, meaning the computer doesn't put enough fuel in it, and it knocks, so the computer retards timing which makes it run like crap. Just a thought... :shrug:
professorkaos93
rules the world
cinci.
where would i find a new throttle sensor? and is there anyway to test the one i have now?(where is that on the car? lol)
Vsho93
Milwaukee
throttle sensor you can get for about $23 at autozone, you can replace it in 5 minutes, just make sure you take in the old one in or at least the number off of it , it turns out my 93 ATX SHO's original sensor was from a 92 SHO MTX and it did not function at all.
AREA 91
Area 91
First, check your codes
Second, clean your MAF with MAF only cleaner.
Third, you can test your TPS with a volt meter.
