big problem!!!
shokid20
East Stroudsburg
ok i just got done doing the 3.2 swap in my mtx and i put the 3.0 cams in and did all the 3.0 accessories on the front like the pulleys and what not. went to start and pops out the exhaust, ripped back apart and timing marks were exactly where they are suppost to be. still does the same thing. does anyone no what i should do or no whats wrong?
Phoenix
SHOHOLIC
QC , Canada
there you go:
RAYJAY
WHO ME ?
UNION DALE PA
got the cams in right ?
Jeff
also your really close to me I'm in Pa also by elk Mnt. ski area
shokid20
East Stroudsburg
im pretty sure i have the cams in right the front of the cams towards the passenger side sproket can only go on one way and the driver side sprokets are lined up with the top of the heads like the book shows.
RAYJAY
WHO ME ?
UNION DALE PA
when you installed the front pulleys you got the dowel pin in ??
shokid20
East Stroudsburg
hey pheonix that diagram up there the 1 and 3 are mixed up and the 4 and 5 are mixed up. your diagram is different then the chilton manual
shokid20
East Stroudsburg
well someting is still not right, still have the poping out the exhaust and i tried switching the 1 and 3 wires and 4 and 5 wires and still nothing
RaJ93
I Didnt See it.
St. Louis Park, MN
This may be a silly one but I have had this happen to others... Is your DIS grounded? my friend didnt have a decent ground and he had the same problems... We ended up running a wire from the firewall to a bolt on the DIS module...
Good luck
gbizzle27
Bradford, Pa
The DIS is the little box with two plug in's on the crossover tube on your intake. Its to the far passenger side of the engine. Make sure the strap that goes from the firewall to the back of the intake on the passenger side is hooked up good, and the two bolts that hold the crossover tube to the intake are in and tight.
shokid20
East Stroudsburg
ok i didnt but that green ground stap on bc i didnt think i needed it to run so this is what is making my car pop out through the exhaust like it was out of time?
sdpatt
Sr. SHO Engr.
Dallas, TX
Chilton's had the 4 and 5 plug connections switched, but not the 1 and 3. Check those plug wires again.
shokid20
East Stroudsburg
ok so i got the spark plug wires on right, it stopped poping through the exhaust but wont start. it just cranks. i have spark and fuel. now what?
Staff online
