Wheel Upgrades
0V3RC10CK3D
Washington
Looking to get some good 17x7 / 17x8 wheels that are good looking, low profile, 5 spoke and light weight. Kind of like the Crono HT's but I'm open to suggestions for anything cheaper. ( around 15lbs? )
SHOspazz92
Banned
Triad Area, North Carolina.
A 15 LB 17'' wheels is going to be pricey. If you can deal with a 6 spoke wheel I suggest some Enkei 0R52's. They can be had for 79 a peice (In 17x7)brand new and weigh 17 pounds.
DSCN2177
-Sam
shomesomesho
G-force addict
more rubber, more HP.....
17x8's are the only way to go. . . :)
As far as I know, crono ht's are the lightest 17x8's currently available (19 lbs).
I've looked hi and lo for o.z superleggera's in 17x8 which are just 15-16 lbs. but they are nowhere to be found. The 17x8 Team Dynamics PR 1.2 are 20 lbs. and a little cheaper, but they are ugly as all ****.
Centerline Storms (link here) in 17x7 are also about as light as you can get (15-16 lbs), but they don't come in 17x8, and the offset of 42mm puts the rim too far inside the wheel well IMHO. They're also more expensive than the crono ht's.
adidas_kn
LOWSHO
Houston Texas
DSCN2177
-Sam
Those aren't too bad looking there Sam. For $79 apiece I think that can be forgiven. Where in the **** did you get them? They would look allot better in black with the lips left machined. Still looking for the perfect light weight 17-18" wheels to help drop my new 89' below the magic 3000Lb number when dry.
SHOspazz92
Banned
I could have got them black with the polished lip but was unsure on how that would have looked. I figured you cant go wrong with a Silver wheel on a Silver car so I played it safe and was darn happy with the results! :)
http://www.edgeracing.com/wheels/enkei_wheel/
Scroll down a bit. They were 89 Bucks a wheel, My mistake! They normally go for 170 a wheel. :type:
-Sam
SeanMc
NoMoSHO
MSR 190s
$450 shipped from James (SC and SHO Blazer)
519290745 8c51b18ee2 b
535191052 45a2460ce1 b
Weigh the same as the Enkei's Sam posted and have the same dimensions, clear Cobra brakes, look hot.
baySHO_510
**** It broke!!
Manteca & Oakland Ca.
Hey shospazz (Sam right?) What size tire are you running? I had 17x8 with 235/45/17... Due to an auto accident Im now in the market for new wheels & tires and Im wondering how much more bubble (on the sidewall) a 235/45/17 would have on a 17x7 wheel.
SeanMc
NoMoSHO
Hey man, my tires are 235/45/17. Hardly any "bubble."
JEM
SF Bay Area, California
A 17x7 is really too narrow for a 235/45-17, most OE 235/45-17 installations are 17x8 and I think 7.5in is the narrowest tire-mfr recommended rim width.
I'm running a one-of-a-kind, third-hand, welded-a-couple-of-times, straightened-and-refinished set of 17x7.5 ROH ZR6s - they're straight, not too heavy, not too light. Right now they've got a set of 235/45-17 Bridgestone S-03PPs on them and they are, as I noted, about the narrowest wheels I'd put those tires on.
Got a set of 17x8 Ronal R41s on the shelf, a little lighter, haven't had them mounted yet.
