question on 17 inch rims and speedometer..
JustinSane
SHO OFF
PA SHO Shop
if stock size is 225/60/16 and thats a 26.6 inch tire then how much would a 225/50/17 tire throw off the speedometer? the later tire is 25.8 inches high thats a .8 inch change surely it must throw it off some. it looks like a 225/55/17 would be a better choice no?
NCTaurusSHO
Guest
Elizabeth City, NC
i run 235/45/17 no problem, I have a tire calculator, because i work at a shop that carries tires let me see here....
stock. 215/60/16 overall diameter 26.2 section width 8.5
convert to : 215/55/17 overall diameter 26.3 section width 8.5
as far as 225/55/17 overall diameter 26.7 section width 8.9
and 225/50/17 overall diameter 25.9 section width 8.9
I'd say you are good to go if you go with a 215/55/17. shouldn't hurt the speedo. there are no changes in overall diameter ..well if .01 makes a difference, and the tire width is the same. just a bigger rim. the other sizes are a bit off.
ashley
SinisterSHO
Rust free
630, IL
My speedo is only off by 1 mph or so. I run 235/40/18, and while cruising if I set the cruise at 75, the GPS will usually read somewhere around 74 and some change. My short snow tires were another story.
JustinSane
SHO OFF
PA SHO Shop
ok my mistake was the stock size, i thought it was 225/60/16 if its 215/60/16 that is just about the same as a 225/50/17 so i should be fine.
jedhead
westminster,ca
When I went to 17" wheels, my overall tire diameter increased because I went from 225/50ZR-16 to 235/45WR-17.
Bob
crazy_canadian
Rattle-Mobile
Quebec
235/55 on the slicer dosen't change speedometer reading.
Dont want to highjack the thread, but my friend has a set of konig 17x7 for sale, wrapped in 225/45-17, is it too small ?
DDakRT
Mississauga, Ont, Canada
235s on slicers? :oogle: That's a horrible combination, 235s are too wide for a 7" wide wheel, let alone a 6" wide slicer.
As for the 225/45/17, that is quite short, your speedometre will read 4.5% faster than it actually is. For 17" wheels, you want to use 235/45/17s or 225/50/17s.
crazy_canadian
Rattle-Mobile
Quebec
Yeah I bought the car with these tires. Falken Ziex Ze-512 in 235/55R16. Quite a nice tire, but way too wide. Sidewalls flex a lot.
But the 225 thing, is that I may get a set of konig appeal custom drilled to 5x108 @ 45mm offset rather cheap. So if they look good I might buy it. But they're small. 245-45-17 is what is closer to stock, but I don't think I can fit them on a 17x7 inch rim.
