Won't turn over
Devin
3.Slow
Pacific Northwest
I spent some time and money working on this myself but am getting to the point where I am stuck. A couple weeks ago I was leaving a store and had a hard start condition where I turned the key and got a rapid clicking noise, and then the car turned over and started.
Fast forward a few days later and the clicking is all I would get. If I held the key in start for more than three or four seconds I would lose all power to the car. No dome light, no instruments, no chime. Chime back to it later or disconnect and reconnect the battery I get power to stuff again.
To troubleshoot I cleaned all the terminals, from the battery, to the fender mounted relay, to the relatively new(ly refurbed) starter. Cleaned the cable ends, tightened everything down, same result. I put a screwdriver across the relay, same result. I replaced the starter, same result. I swapped out the relay with an old one from my parts bin, same result. I took my battery in today and it tested good.
Any known problem areas that I haven't listed?
Thanks for the help.
zoomlater
Seattle, WA
if you search for starter solenoid, some of these posts come up. Can you measure the voltage at the solenoid and at the starter? How old is your battery?
ScotSHO
Lewiston, NY
I vote a corroded wire, potentially the large gauge wire running from the battery to the starter solenoid, or solenoid to the starter. As it sits, check continuity from the positive battery terminal to the starter solenoid. Same on the other side of the solenoid to the starter. Should be very low resistance.
Separate problem symptoms, but I had a bad connection on the large wire running from the alternator to the solenoid. I thought the alt was bad but it turned out the wire was corroded and falling apart a few inches in from the alternator.
Irish Pride
Irish Inside
MusicCityUSA
Run 12 volts directly to the starter side of the solenoid. If the starter turns over then you need to replace the battery cable to the solenoid.
-Chad
Devin
3.Slow
Pacific Northwest
3 ohms from the battery post to the solenoid post. 0.6 ohm from the solenoid terminal to the positive terminal on the starter motor.
Measured ~0 from the negative post to the ground screw next to the solenoid. From that same screw to the wire on the stud at the transmission case the testing bounced around. To the starter case it was a little bouncy but was between 0.5 and 2.5 ohms for the most part.
Devin
3.Slow
Pacific Northwest
Ran battery straight to the terminal on the solenoid and the starter turned over. Solenoid?
Texas Marauder
Lone Star State
I'm vaguely familiar with the early SHO starting system. What year is your car? How many connections on the solenoid, 3 or 4? Should be 3, IIRC. You want to, sort of, make a chain. Always starting at the battery post. Connect one lead of the voltmeter to the battery post and the other to the connection you are tasting. From the battery post to the battery terminal, then to the next connection, which is the solenoid, then to the other side of the solenoid. You'll have to energize the solenoid to check that. Next, to the connection at the starter. Also, have to energize the solenoid for that. Then on to the ground side. .015V is a good reading. The number should increase as you get farther away from the battery but, nothing drastic. A large change indicates a bad connection.
Devin
3.Slow
Pacific Northwest
It is a 90, and there are three studs.
Any idea how to activate the solenoid without using the ignition? Can I just feed it 12V?
zoomlater
Seattle, WA
Take a look at that engine harness I gave you, maybe the wires you need might be in there
lukepe
NH
take a pair of jumper cables using on side black or red jump from engin block to battery ground wiggle cabels to be sure a good conection and try again jumping solinoid smal terminal to battery side will eliminate igntion circut and cabels will eliminate endin to body/battery issues see what happens good luck
Devin
3.Slow
Pacific Northwest
I used a jumper cable as the pos with the same result.
Thinking about the @TankII post, I tried putting the battery in thr Land Cruiser and... same result! 12.6V and everything. So I'm charging the Land Cruiser battery and seeing if this will start the SHO
