Any issue swapping doors?
406SHO
Billings
Hello, thanks for looking. I have a 2015 SHO in the RR ruby red tri-coat paint color. My passenger front door was damaged and I’m looking at finding another door in that color to swap out. Will I have any issue with using one from a 2014 or other year? Plan is to just swap all my interior door trim parts into the new door if I can find one in the RR paint code.
Majestic
As far as I know, 2013 up are the same. You can probably find one that matches your interior, too.
Jake0811
Macomb MI
Won't be too hard to find an identical color door from a 2013+ SHO. Just swap over the door panel and that should be it! As long as all the electronics work you should be golden! I swapped out my rear decklid on my 15' SHO about a month ago with one from a junkyard RR 15' SEL that had the same spoiler as mine. It fit perfect and I swapped my "SHO/ecoboost" badge over and cleaned up my car and it looks good!
You are good. 13 and up are all the same.
