ECU - Brain
Hollon71
Harlingen, TX
Try here.
Thank you. Lets see if something can happen here. I also came across this one as well:
You can make or have harnesses made. It would not be cheap. People who preserve vehicles or make custom ones have to do this.
Hollon71
Harlingen, TX
I just found that out from the e-mail I got from Ron Francis, who I emailed earlier today.
"I believe you are looking for a REPRODUCTION harness. If you are planning upgrades, then we have what you need.. Ron Francis Wiring builds custom wiring systems for modified cars and trucks where the engines have been changed or a new set of gauges or different steering column. We do not make reproductions of stock harnesses. We can help owners who plan upgrades which seem simple but affect a lot of areas of the vehicle. If you are making changes or upgrades, the stock connectors become less important. Especially if they are burned. We also offer stand alone Fuel management Systems for installing a newer engine into an older vehicle.
Our custom systems are not going to look anything like a factory harness. It is made so you assemble the whole car or truck one circuit at a time and then wire tie or wrap the finished product. This allows for a far less confusing installation and allows you to install wires where you want them which is very important to you for that kind of application. It covers the whole vehicle but is not compatible with a partial harness from the factory as we use many upgraded products like a whole different fuse block.
In a hurry to see the current catalog? Go here to see it->
https://s3.amazonaws.com/cdn.ronfrancis.com/downloads/RFW_Catalog.pdfHope this helps,
Ron"
Hollon71
Harlingen, TX
I ordered THIS that will arrive next week, off eBay. A 1999 Ford Taurus & Sable Wiring Diagram Manual. I hope THIS will show me everything that I need.
gamefanatic
Barstow, CA
That works. If you want a digital version I recommend https://eautorepair.net (Mitchell1 DIY). They have always had good wire diagrams and highlight traces.
Hollon71
Harlingen, TX
Look what came in this morning, from my DC location in San Antonio!!! I will have to see if it shows any wiring, or not. I have another item arriving today FOR the wiring.
Hollon71
Harlingen, TX
Well, THAT was a joke. In it, it states it's not for the SHO. Now, I'm still waiting for the other item to arrive. Must be expecting to arrive tomorrow since it stayed in San Antonio over night.
Hollon71
Harlingen, TX
Well, darn. This is the one I bought that will arrive tomorrow. When I get it, I will just have to see what all it provides.
Hollon71
Harlingen, TX
The 1999 Taurus/Sable "Wiring Diagrams" book arrived today. It DOES contain the information on the 3.4L SHO. Now that THIS is in my hands, I will be taking my sedan somewhere so the can check everything, staring with the wiring connections at the battery.
When driving the sedan, every second, you feel the car is not wired/connected properly. Many times, the a/c works. Sometimes, the a/c will not work and it has freon in it. Again, there is something not wired/connected right with my SHO.
Hollon71
Harlingen, TX
Lots of things to look at.
