Exterior Plastic Trim Discoloration
ShoDoGo
Does anyone have a good way to treat the plastic trim that runs around the perimeter of the car along the bottom? It's turned grayish over the years and I would like to make it black again to match the body. I'm considering spraying it with rattle can bedliner spray unless I can come up with a paint that will work. It's on an '11. Ideas?
6500rpm
The absolute best and right way is to pull the lower rockers and door trim off and carefully mask the rear. Wash all that stuff down with soapy water/degraeser. Wipe it down again with a liberal amount of lacquer thinner or alcohol to get rid of all traces of any wax or trim product. Spray it first with a plastic adhesion promoter like SEM 38363, then spray with SEM 39143 Trim Black. At some point in the cleaning process you may wish to use a light scuff pad, and it's advisable to buy a set of panel retainers from the dealer as some will most likely break during removal. My cars a daily, I think it's been 3 years and it still looks great and you'll never have to worry about it looking grey and chalky ever again. You're also going to be shocked at how much dirt and gunk is hiding behind those trim panels. Those wipe on products are just a temporary bandaid. This a about $100 in material, looks great, and permanent. It's also real black, not blackish. I just walked out and snapped these pics, ran it through the wash yesterday.
NegraSho
Nebraska
The absolute best and right way is to pull the lower rockers and door trim off and carefully mask the rear. Wash all that stuff down with soapy water/degraeser. Wipe it down again with a liberal amount of lacquer thinner or alcohol to get rid of all traces of any wax or trim product. Spray it first with a plastic adhesion promoter like SEM 38363, then spray with SEM 39143 Trim Black. At some point in the cleaning process you may wish to use a light scuff pad, and it's advisable to buy a set of panel retainers from the dealer as some will most likely break during removal. My cars a daily, I think it's been 3 years and it still looks great and you'll never have to worry about it looking grey and chalky ever again. You're also going to be shocked at how much dirt and gunk is hiding behind those trim panels. Those wipe on products are just a temporary bandaid. This an about $100 in material, looks great, and permanent. It's also real black, not blackish. I just walked out and snapped these pics, ran it through the wash yesterday.
So the trim from the bottom driver side fell off where can I buy the clips and screws for it? And that looks
Texas Marauder
Lone Star State
Reading the service manual, the rocker panel trim and the lower door trim are one time use only. If you remove it you must install a new part.
6500rpm
I purchased mine at my local dealer. Be sure that they understand which trim part , I'm thinking when I pulled off the rocker panels and door trim there were 3 or 4 different styles in all.
