Cooling System - Overflow Cap
Ta2dResqr
Central Ohio
Looking at another members mod list I noticed a radiator cap. I remember when running a boosted import, I upgraded from a 1.1 bar to 1.3 bar to get an extra little cushion (~8.7*) and it allowed the coolant ratio to be played with a little more without fear of boiling. I started looking around and all I can find is 1.1 bar for our application. Has anyone played with this at all? Is it avoided due to the cap being on the overflow instead of on the radiator? I was able to find some newer applications that used the 1.3 bar cap but I am not sure if it is the same fitment. I also found Super Duty trucks used a 21 psi (~1.44 bar) cap.
1.1 bar is 16 PSI in case this helps. 1.3 bar is nearly 18.9 PSI
I did do some poking around to all kind of sites - 16psi or 1.1bar seems to be the fare. Aren't you concerned you will cause the reservoir to spring a leak?
I would say, he is just looking for that cushion.
Ta2dResqr
Central Ohio
I am not concerned about the system getting a leak. It is less than 20% pressure differential. I have run it on other systems and I have also tested my system at 20 PSI. When using a pressure tester, I usually set it for 4 or 5 PSI higher than the cap looking for weak spots. Rather find it in the garage than on the road. In theory, the system would still operate as normal unless it was being stressed. If your 16 PSI cap reaches 17 PSI, it will "burp" and allow coolant out the overflow hose. Doing this enough would cause a low coolant issue. The fact that it doesn't happen is because the system generally operates under that level. This would mainly be a little extra safety for "spirited"/track use, the additional heat generated by more power/boost, and anytime you may get stuck in traffic on a really hot day. It would essentially allow the car to get about 9* hotter before the coolant boils.
Thanks for explaining your thought process - I understand the intention much better. Shame I was having the same issue as you. Very hard to find.
Mahu24
Prince George, BC, Canada
Have you had any issues with your car getting too warm? I beat the c*** out of my car almost daily and never seen the coolant temps very hot on my tuner
Ta2dResqr
Central Ohio
Not yet, however, I have now gone to Stage 3 turbos. I am expecting more heat to be generated. Combine that with the fact that I regularly experience ~15 minutes of spirited driving followed by ~30-45 minutes of idling, and I would like to have the extra cushion.
Mahu24
Stage 3 CR Performance turbos?
I ran 9, 1/4 mile runs, back to back and didn't see my coolant temp raise at all.
Ta2dResqr
Central Ohio
Well I talked to MotoRad (who owns Stant) and got it figured out. The correct cap with a 20 psi rating would be a T54.
MotoRad Taurus - T38 16 PSI
MotoRad - T54 20 PSI
FORDFOCUS2008-2011
LAND ROVERDEFENDER 1102020-2021
LAND ROVERDISCOVERY2017-2020
LAND ROVERRANGE ROVER2016-2021
LAND ROVERRANGE ROVER SPORT2016-2021
LAND ROVERRANGE ROVER VELAR2018-2021
MERCEDES-BENZML3201998-2003
MERCEDES-BENZML3502003-2005
MERCEDES-BENZML4301999-2001
MERCEDES-BENZML5002002-2006
MERCEDES-BENZML55 AMG2000-2003
Using the 2008-2011 Focus:
Motorcraft - 9S4Z-8100-B or RS259
I went with a Motorcraft part for the OE look and quality. You can cross reference the MotoRad or Motorcraft part numbers to the manufacturer of your choice. I know Dorman and Stant both have applications that match. Make sure to look for the overflow or degasus cap. The Focus also has a traditional style radiator cap that you do not want for this application.
FORDFOCUS2008-2011
Congrats, I went to MotoRad site and Stant nice job getting them to x ref.
