No sound
SHO'd ya NC
Franklin, NC
New SHO owner (a 2015) and new to forum.
I don't get any sound at all from the infotainment system. No stereo, no touch feedback from screen, nuthin'. Tried factory reset and battery disconnect.
Suggestions?
SHOrod
Torrie Tuned
Cedar Rapids, IA
Welcome to the forum! Does the screen seem to be working normally otherwise? Do other features work properly such as the climate control and navigation? Have you checked the fuses for the audio amplifier?
-Rod
SHO'd ya NC
Franklin, NC
-Rod
Hey Rod. Climate, fan speed, heated & a/c seat controls all work, although not even a beep when you touch the screen. Haven't needed nav., but it knows what road I'm on. Haven't tried the audio amp fuse, and hinestly didn't know there was one. Happen to know where that one is located?
Thanks, Keith
SHOrod
Torrie Tuned
Cedar Rapids, IA
I don't have access to the service manual for the 2015 model year. If it hasn't changed from the 2014 model year, then it's Fuse 5 (20-amp) in the Body Control Module (BCM) fuse panel if you have the Sony system. If you have the owner's manual, there should be a fuse listing in there. Additionally the fuse panel covers/doors usually have a brief fuse listing as well. It may be listed as "DSP" or "ACM." If you don't have Sony it should be Fuse 29 (20-amp) in the BCM fuse panel.
-Rod
SHO'd ya NC
Franklin, NC
-Rod
Thanks much Rod. I'll let ya know how it goes.
Keith
