Tick
Is it coming from inside the engine? Does it change with rpms?
I would look --on the outside maybe a pulley or tensioner issue or cooling fan --something that goes round and round
inside--yikes. are the cams welded?
Texas Marauder
Lone Star State
Classic sound of loose cam gears. Do not run the engine until you pull the valve covers and check the cam gears. If not welded, do it now. If the gear slips while running it will bend valves.
SLOWgod
Weeeeeeeeee
I know they aren’t welded guy I got it from parked it bc that reason
SLOWgod
Weeeeeeeeee
It sounds like it’s coming from the engine it doesn’t change with rpm. The cams aren’t welded
Take off the intake and valve covers and look for camshaft slippage. They are swedged together not a solid piece where the shaft meets the gear. I swore someone must have mentioned welding those things. Damn. Maybe you'll get lucky and it's savable or not cams at all. I would never trust a non welded cam on the v-8s. Mine was welded and engine was still strong at 200k miles. Got rid of it for failing tra nny
SLOWgod
Weeeeeeeeee
Runs fine no issues idles great maybe I can get away with just welding the cams
Maybe. If it is the cams. They are now loose and can quickly slip, get the engine out of time, have the valves contact the pistons and potential to damage the cylinder. I would not start it again if possible until cam is confirmed. Rear cam fails more often than front but both can fail. Also don't just look at the gear mating area. Check out the lobes for damage and how they are lining up to shims to make sure it hasn't slipped too much. No point in welding a cam in a position that is not correct or a cam that had lobes that are damaged.
SLOWgod
Weeeeeeeeee
I think I’m a 100% it’s the cam my white car (rip) was making the same noise when I got it and the cam went
check the damage and see if it fixable. I do like those engines except for this flaw.
SLOWgod
Weeeeeeeeee
I
It’s the front one making noise so lucky it’s easy to pull up i will do thay next week and up date with pics see what you guys think
SLOWgod
Weeeeeeeeee
Update !
Check the cylinder and see if there is any damage. If not maybe cam or head swap can save it. Anything that involves keeping this car requires a cam weld going forward. This happens alot and people come on here like nah... won't happen to mine. It is a flaw of all of them
SLOWgod
Weeeeeeeeee
Yea that’s how my white one was but this time im not going to keep running the car I can save this car for the meantime it’s going to sit till spring
