Front control arms boys
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
Had to get front alignment also in total I spent 870 labor and parts
That's not too bad. On RockAuto the control arms are $87 each, plus shipping you're at $200 for the pair. $100 for alignment, 4 hours of labor at $120/hr plus you at $780 plus tax. If you don't have the working knowledge or the space/tools to do it yourself it's a good idea to have someone else do it, plus you have a warranty on labor to fall back on it if it DOESN'T fix the issue.
paul65584
missouri
I replaced both on my 2010 yesterday, took about 1.5hrs per side. the second side was easier over all because I knew what I was doing. Ball joint was ******* the second side or it would have been a lot quicker. Break the ball joint loose then remove the long bolt. finish taking the ball joint loose then remove the aluminum housed bushing. reinstall in that order.
VwCSilent
FREDERICKSBURG, VA
Fwiw I bought the ones on rock with the ball joints in them. Pretty straight forward job with an impact, prybar, jack, and stands. I only needed to replace the ball joints but after comparing the cost/difficulty removing, opted to do the whole arm.
SeanDev
Good call, so much easier to replace as unit vs presses out bushing and bearings.
