WTB. Shim Kit
JohnM
Chicago
Thank you, seems fair and complete at first glance.
Hopefully shipping/tax won't send it off the rails.
I'm surprised there aren't great piles of shims laying about everywhere. They are oddly difficult to find.
Irish Pride
Irish Inside
MusicCityUSA
I have over 300. If you need a standard size let me know. The odd ball sizes I tend to hang on to though.
-Chad
tompumped
VT
Say someone does need an oddball size? Wasn't there a post years back that said there were powersport shims that worked fine, I think they were for a yamaha motorcycle.
JohnM
Chicago
I think the range is from about 2 to 2.7, so oddball by the definition above is around 14 sizes vs the 6 others.
Sent from my SM-G965U using Tapatalk
JohnM
Chicago
I think the range is from about 2 to 2.7, so oddball by the definition above is around 14 sizes vs the 4 others.
Irish Pride
Irish Inside
MusicCityUSA
The sizes range as follows - 2400, 2425, 2450, 2475, 2500, 2525, 2550, etc..... The most common shim size by far is 2500. When doing a valve shim on stock heads with stock cams it is very uncommon for me to need anything smaller than 2400 or larger than 2600. Partly for that reason those sizes are less common. I probably have 50 2500s vs maybe 3 or 4 2675s. These odd ball sizes become very important when dealing with custom ground heads and cams.
-Chad
kwforddude
Ontario
Can anyone give ford part numbers and any updates cross reference part numbers for shims.
