PP Struts
Roman
Mi
Okay Guys, so I have a non-PP SHO and I'm going to be installing some H&R springs soon, but I'm going to be replacing my struts, I have a 2016 and was told I have a internal issue with my strut but I want replace and install with PP struts, does anyone know the part number for the front and back PP struts?
Sorry for so many PP's lol 16c7f8b5bbeb10cfbdc27e1ebc2c7377
Michigan-SHO
Michigan
Your best bet is to call the parts department at the dealership to make sure. Sometimes they are cheaper too.
Johnbigdog
michigain
I have a 16 P.P. (1FAHP2KT2GG124764) and just replace the front struts (shock, spring, upper mount), lower control arms, inner and outer tie rods, and sway bar links. I would also recommend buying new upper nuts so you don't have to take apart your old struts for the one part:
RHF shock - DG1Z-18124-W (these come with bellows and bump stops)
LHF Shock - DG1Z-18124-U
Spring - DG1Z-5310-K ( i'm right here maybe this P/N may be helpful to someone in the future)
Upper mount - FB5Z-18183A
Upper shock nut - W713968-S440
Rear - DG1Z-18125-F
The lower control arms now supersede to the part with the hydro bushing with the control arm!
RH: FA5Z-3078-A
LH: FA5Z-3079-A
Sway bar links:
RH: GG1Z-5K484-A
LH: GG1Z-5K483-A
Roman
Mi
Spring - DG1Z-530-K ( i'm right here maybe this P/N may be helpful to someone in the future)
Rear - DG1Z-18125-F
RH: FA5Z-3078-A
LH: FA5Z-3079-A
Sway bar links:
RH: GG1Z-5K484-A
LH: GG1Z-5K483-A
Thank your so much!
Johnbigdog
michigain
Some of the springs say that they aren't for the PP?
There appears to be 13 (front and rear) spring options listed in the parts catalog. That part number is by VIN.
