Transmission upgrade
yaycandy
Aerospace Engineer
Hanover, PA
I posted about it last year and I think another forum had about it also. I dont know of anyone who has installed it.
I have wondered if it is a viable solution.
My thought is a rebuild due to failure such as [mention]SM105K [/mention] had or someone like @Wsho or @Jordan_R
Yep mine was the infamous snap ring failure. If this replacement is a viable solution, then that would be great.
Wsho
Sacramento California
I purchased a new transmission because I wanted too not because mine failed I did it because I wanted a new transmission to go with the new motor there was no point putting 136k mile trans on a 0 miles motor.
bpd1151
Lurking Around
SHOcago 'Burbs
^^^completely on board with this^^^
Exact same rationale I've employed with my current rebuild.
Absolutely did not care (despite a completely functioning trans) to go chasing after perceived failures given the goals with my new motor.
I applaud your foresight there wsho!
Michigan-SHO
Michigan
I didn’t mean you blew yours, I was referring to those that were doing full rebuilds with increased power. And knowing that the trans is the weak point it makes sense to increase the capabilities of the weakest link.
Jordan_R
Missouri
I mean, I'd be willing to say the motor is the weak link at this point considering that and the diff are about the only things OEM in the powertrain anymore in my car HA!
Michigan-SHO
Michigan
Haha! Those are some spicy words!! I can’t wait to see the results.
Jordan_R
Missouri
I will say however I think the whole the trans is the weak link is a pretty dated thing. I think really the issue was in the beginning the tuning style was to take away majority of what saves the trans because that's what other platforms do. I.E. Torque management.
I know for sure that the torque management side of things has gotten extremely advanced in comparison to the point where load targets are used as a secondary torque management with heavy timing retarding if you go over commanded load. Basically another mitigation of boost spikes on top of throttle closure.
Things I am doing to make my 136k mile trans last is I have put a GH torque converter into the mix and I am putting a beefy trans cooler on it and I might pull the thermostat out of it due to the car being upgraded to weekend warrior / nice weather status. This time around I think we are going to tune around keeping the torque lower just to keep everything happy. It's cool to say you have hella torque, but man I would love to be able to brag about hella horsepower instead LOL. We need some proper damn cams for some revs!!
yaycandy
Aerospace Engineer
Hanover, PA
I seen a better tranny thermostat somewhere before. Not sure how much lower either
yaycandy
Aerospace Engineer
Hanover, PA
I'll just throw a weight reduction joke out there and say just no thermostat will make the car faster anyways
Remove 2-3 lugnuts a wheel. Weight reduction.
Wheels usually are going faster than the car when they fly off. Should trick the speed trap at the end in turn lowering your quarter mile time.
limited02
Olathe, KS
There was a guy on FB who had custom 2-piece rotors made by his friend overseas that shaved a good chunk off the front for rotating mass. Myself and another guy inquired, but no real response.
