Anyone encounter this?
ShogunofHarlem
Missouri
It just fell off, and I'm sure the dealer will want my arm and leg to replace it. Any cheaper places out there and is it difficult to install?
Ecoboost_xsport
Sacramento, CA
Look for the part number on Tasca and see if you can just install it yourself. Might take a bit of research but looks to be installed with just double sided tape.
skyshadow07
Oklahoma
I did double sided tape and it came off again. So I would advise towards the stronger stuff. Maybe gasket maker if you want something removable but very strong.
Ecoboost_xsport
Sacramento, CA
The dark gray 3M stuff is pretty strong. But you have to make sure the surface is cleaned and wiped with some denatured or rubbing alcohol. Get rid of ALL surface oils
