WOT Issues
Joe Smith
ohio
2013 PP With Livernios 93 Tune. 3Bar map. CAI. SparkPlugs.
The car runs absolutely beautiful regular driving. Even aggressive driving, perfect. WOT is an issue. Almost like when in full boost its rocking back and fourth at around 4700-5500 RPMs. Sometimes after a few RPM Cycle's it Straightens out. Bad Injector? Weak FP? I usually run Shell 93.
Did you have a 2 bar tune or stock tune. Just looking at tune vs oem programming vs something else causing the issue.
Joe Smith
ohio
It was tuned on 93 with the 2 bar. I ran 7 months no issues. I don't think its the tune
Can you put your car back to stock?
Jordan_R
Missouri
Do you have access to sct or hptuners datalogging? I'd be half tempted to say fuel pressure is dipping but it's not in my practice to just throw parts on hunches. Also plugs that are warn and the gap has increased will cause stutters in the higher powerband
I agree with this as well.
Csbbrah
Ky
+1 start with the easy things to check. Plugs etc.
Sent from my LM-Q610(FGN) using Tapatalk
ridered74
yes, it still does it, but not as bad
What part of Ohio are you in? If you are near any of us that have an SCT device, might be able to help by hooking it up and watching a few things live like fuel pressure.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
agreed, sounds like either fuel pressure, or possibly knock. are you flashing a CEL or anything during the issue?
or you could get the stock tune loaded and have a professional tech with a good diagnostic computer look through all the systems and see if it can pinpoint running and stored errors. always an option
gwrabbit
Wisconsin
I had this issue on my 2013 PP. No tune, but when I tried to gun it, the car would start jerking and rocking back and forth. Took it into the shop and they replaced spark plugs + coil boots. Issue went away after that. Might be worth checking out but like others have said, get a technician with logging capabilities to take a look.
Joe Smith
ohio
Stragely enough I added some octane booster and fuel injector cleaner and it ran perfectly yesterday.. just a little smoke at WOT
