DW300c Fuel Pump Assembly
Ecoboost_xsport
Sacramento, CA
Just a short (by short, I mean LONG) and unedited video of the install of the DW300c into the hanger assembly. Pretty straight forward but there are a few things not covered in the instructions and some helpful pointers I discovered. Perform at your own risk. Definitely one of those "how the sausage is made" videos and if you have an aversion to cutting into OEM stuff, it might make ya squeamish, LOL. Anyway, just one way I found to skin this cat, I'm sure there are others.
Part 01
Part 02
Part 03
Stock LPFP hanger assembly:
IUkEbwJjQuOaM6width498height1024cropmodenone
DW300c in the box:
IcMpCPGDfhI26hwidth1024height498cropmodenone
Some comparison photos between stock pump and DW300c:
24uF0CIclNzR3jwidth498height1024cropmodenone
KVfL8uBu3f4j Owidth498height1024cropmodenone
F85A0obqotraeqwidth1024height498cropmodenone
Comparison photos of the stock filter sock vs. what comes with the DW300c. In the video, I show how you will have to slightly modify this part to make it fit right.
CraPV7ER875UIjwidth1024height498cropmodenone
De8vcbwm2O Sevwidth1024height498cropmodenone
ZGIgETPaNyp0FBwidth1024height498cropmodenone
F 3ho1qVjyyyRnwidth498height1024cropmodenone
Silicon plug to keep the plastic shavings out of the pump internals when trimming the inside.
A0GO FH1X SRJnwidth1024height498cropmodenone
Video showing how the DW300c doesn't fit right into the filter sock. This is before modification of the sock assembly.
A few more close ups of the wire connector (Toyota PN: 90980-11080) I modified in the install video.
SHs do5l6Bu8ljwidth498height1024cropmodenone
Links to the pins/splices you'll need:
KXyfJofSikZM6Gwidth498height1024cropmodenone
RvsNCUBFZyHhejwidth498height1024cropmodenone
Here's some extra pics if anybody wants to know details on the fuel pressure relief valve that is inside the hanger.
AxSgB7IakH1eyOwidth498height1024cropmodenone
MWN8iv0v3UoynGwidth498height1024cropmodenone
NbhPvtow6hRfXAwidth498height1024cropmodenone
UYjNI0EvT2e6CWwidth498height1024cropmodenone
bpd1151
Lurking Around
SHOcago 'Burbs
A pleasure to see others like yourself, stepping into the foray of documenting and providing a "How-To" tutorial.
Much appreciated. By myself, as well as others looking to perform the same upgrade.
Thanks and nicely done!
Ecoboost_xsport
Sacramento, CA
Thanks. I'm new to making vids and not skilled in editing them. I've got 1000s of photos of everything I do, but the circle of friends I hang with always tells me to video what I'm doing, since I do 90% of my own work. I'll post more of them. I started a YouTube channel with them as well, but I'm sure I'm a boring YouTube content provider, haha
Anyway, I prefer unedited vids as I can see every step. Too often I go to a YouTube vid that is edited down to 6 or 7 minutes and something I was interested in seeing got glossed over. I would venture to say that it isn't too hard to fast forward through the boring parts lol.
Thanks again
ridered74
Thanks for the video. I like that you included the struggling parts. Leaves more realistic expectations. Half the frustration of doing some things to your car is watching a 4 minute video where everything is easy and done in one try, and the reality is it almost never goes that easily.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
awesome. Out of curiosity which instructions did you use? The ones made with my basket assembly that are posted on our website or the ones that came with the pump? I guess I need to open one and see what it comes with these days.
Ecoboost_xsport
Sacramento, CA
Thanks for the love.
Your website? Not sure what's on your website as I've never been on it. I used instructions emailed to me by Dakota over at DW directly. The instructions they sent were pretty accurate, most of my "additions" are either clarifications or tips I figured out.
15SHOPP
Cincinnati
Now that you have the experience and some spare connectors...want to assemble one for me!?!
FiveLeeter918
Tulsa, OK
We worked with Brandon at Deatchwerks to improve the kit to have it as realistic as possible to install since it was previously listed as "plug n play" as they were unaware the 10-12 and 13-19 options were different.
Your website? Not sure what's on your website as I've never been on it. I used instructions emailed to me by Dakota over at DW directly. The instructions they sent were pretty accurate, most of my "additions" are clarifications or tips I figured out.
When we bought ours it clearly wasn't plug n play and there was no pigtail nor instructions. We worked with Brandon at DW to come up with these instructions:
https://static.wixstatic.com/ugd/24ef8e_29c2bb62fba24eb281b0dd68bdebce17.pdf
Ecoboost_xsport
Sacramento, CA
Yup those were the ones, Dakota had emailed those to me. They were pretty spot on instructions, so congrats, they helped quite a bit. But me not being a fan of butt connectors (and I have severe OCD, lol), decided to go one step further and make that plug harness a true, complete, uninterrupted piece with the terminal ends, instead of splicing. I also found that a 1 1/2" spade bit worked pretty decently to get rid of that ridge, but only because I didn't have a 38mm hole saw at the time. I will say though, that's it's probably easier with the 38mm hole saw.
Ecoboost_xsport
Sacramento, CA
haha...I hadn't really thought about that yet, I guess it's possible. I do a lot of work on cars/bikes locally, so it wouldn't be out of the realm of possibility, if people were interested. I will admit though, I'm famous for working VERY slow (but methodical) and I'm not usually the cheapest guy in town.
TBH though, this isn't really too difficult of an install as far as modifications go.
15SHOPP
Cincinnati
I was only half kidding. Still undecided as to whether or not I’m going with the GH turbos.
Ecoboost_xsport
Sacramento, CA
Are they offering some version of their own turbos or are they the ATPs? I've spoken with Matt over there a few times about other stuff and never knew they offered turbos, but I never bothered to ask since I already have the ATPs.
FiveLeeter918
Tulsa, OK
GH offers a hybrid turbo
StealBlueSho
NA
Ah, yes, the CHRA I'm assuming. Yup, that's a nice upgrade from stock and will bring plenty smiles per gallon, LOL. I've seen em sold at various locations but only as the CHRA portion, with you having to do the conversion itself.
No. It’s not just a CHRA slap. There is more work done to them than a CHRA replacement.
Jordan_R
Missouri
It's a rework of the OEM housing just like ATP's. ATP turbos are also hybrid turbos except just barely bigger than GH turbos. GH Turbos are good for every bit of 550awhp though while retaining OEM like spool which is the GH turbos claim to fame while the ATP's have a little bit of lag.
