Boost
jtmartin8819
Indiana
This normal boost? Only unleashed tuned ngk plugs, and airaid intake.
jtmartin8819
Indiana
That’s not sustained boost... it’s a peak... the x4 in that mode only displays max and min...
When really getting into it, it stays about 14-14.5.
As far as sustained boost, what is the max safe point on stock internals?
StealBlueSho
NA
Unless you have a bigger fuel pump or meth, you will run out of fuel first.
And it’s more about load than boost... you can have a lot of boost and no spark or vice versa...
I’m running at 1.80 iirc load and Matt said max is 2.0 on internals... and that’s iffy..
