Speed Limiter
ridered74
I have a 2015 SHO and I was just wondering if it has a top speed limiter
From factory yes. I think it's about 120ish if I remember right. Never been that fast in mine.
jman1200
Ontario
The parameters of my 93 octane tune read "Speed limiter: Off" so I assume this can be overridden.
toms89
My stock tune file I viewed from SCT has it set at 131. (2010 Taurus Sho) Not sure if they changed it through the years or for the PP. My guess is just about every tuner turns this off.
High on Ethanol
Just Ain't Care
USA
Stock was 131. I hit around 160 after being tuned, possibly rev limited or maybe tuner set. Not advised, car definitely wasn't intended for that speed.
Roger Batts
Dallas/Ft Worth Area
I have a 2015 non-PP that is all stock. I just checked the parts catalog here at work, and it says it doesn't have an electronic speed limiter. I have had mine up over 120 before, and it acted like it wanted more.
They are when they are lowered. My car is a dream at that speed.
Zpak
Es Aich Oh!
The region, Indiana
Yeah my 2014 non PP was 130 in Drive and 132 in Sport. I had it lifted with my tune and yes, it’s gone now. I hit the limit of 140 on the speedo and it was still pulling so I’m not sure where it ended up.
Andrew C
Alberta
My 2015 non pp cut out at 210 kph not sure if it's a Canadian car thing or not as I see some other folks getting quite a bit more speed out of their stock vehicles
Auggie
Maple Grove, MN
I think that is around 130 mph right. So I was right around that speed but did not feel any engine cut out ? I hope mine will go beyond that. I will try this again !!
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
Speed limiter is definitely removed with a tune. Even a NA car Id get the speed limiter removed. Imho speed limiters should never be on any car. Speaking of though I have no idea how fast mine can go. I've gone over 140 a couple times...in those couple seconds while still accelerating...in a 65...its like what am I doing? I can't even see my speed...
grayj1979
KCMO
Strange, I have 2015 SHO PP and it definitely hard cuts at 115. At least this looks like it will go away when i do a tune this spring.
DARTHSHO
South Florida
2014 SHO PP here with the police mode no governor went 135 wanted to give it more but started to get close to some cities :/ mom was excited though. She was like my BF in college took me 120 I was like that’s it ;)
