Mr.ShoFast
Hello Everyone,
I need help getting my non-PP SHO back up to its normal self again. Below is a summary of the events and the error codes:
Flashing CE light under WOT or when accelerating and trying to pass a vehicle
P0300 --> Random Misfire Detected
P0301 --> Cylinder #1 Misfire Detected
P0302 --> Cylinder #2 Misfire Detected
P0303 --> Cylinder #3 Misfire Detected
Random occurrence on this code
P0087 --> Fuel Rail/System Pressure Too Low
After SeaFoam in the TB
P2196 --> O2 Sensor Signal Stuck Rich Bank #1 Sensor #1
P2198 --> O2 Sensor Signal Stuck Rich Bank #2 Sensor #1
Background:
* bought the car used from Florida --> shipped it to Los Angeles in June 2018
* has been working just fine up to just last week
* car was working fine with the blow-off valve return hose removed since June (but its back to OEM now)
* normally used 91 Octane but pumped at ARCO and used 87 octane...that's when the problems started after the second fill up!!!!!
* since then I'm back on 91 Octane
* used Marvelous Mystery oil once and that's it
* would use Lucas Octane Booster (+3) when I pumped 91 octane (here and there)
* would use SeaFoam in the fuel (here and there)
Issue prior to the Misfire:
* the small hose that controls the turbos (the one w/out a clamp) came off - I noticed a power surge at around 60 mph and along with a constant release/activation of the blow-off valves while driving. Read about it online and reconnected the hose...secured it with a small clamp and worked just fine until the issue below...
Now the Issue:
* as most SHO owners...I did a high speed run under 100 mph and check engine light flashed followed by limp mode
* CE light came off after a few miles but when I pushed the car WOT the issue came up again
* used SeaFoam in the fuel to see if it would help clear contaminants and so forth --> nothing changed
* replaced spark plugs with MotorCraft SP534 (will need to double check the boxes for that #) but issue continued
What I found on the web:
1) replace the plugs = done
2) test/replace coils = don't think this is the issue
3) drill a hole in the bottom of the IC (inter-cooler) due to a build up of condensation - wasnt SHO specific but EcoBoost related --> not sure I want to do this yet
4) have the car flashed and maybe that can set a clean baseline - I do feel the car had a Tune before (it goes over 140 mph)...but how can I tell this was modified?
...Would like to check in with the fellow SHO lovers for other ideas before the dealer rips me off...Thank You
Background:
Now the Issue:
