Keyless entry
Status
Not open for further replies.
Driver5
Poulsbo wa.
I have a 93 ATX with keyless entry number pad on door. I have a 93 MDX electric door locks but no pad on door. I want to take the driver's door off of the ATX and the box out of the trunk and put it on my MTX is there going to be any problems
Driver5
Poulsbo wa.
You need the wiring harness from the driver's door with the keypad (which you get if you literally swap the doors) and the wiring harness that runs from the A-pillar back to the trunk. To r/r the wiring harness, you need to remove all the trim pieces on the left side of the interior (driver's kick panel, drivers door bottom, B-pillar, rear door bottom trim) and also remove the rear seat and seat back, as I recall.
Status
