Car acting wierd
Ben R
When my car is parked it is randomly putting the passenger and driver window down and opening the sunroof. The car is all locked up. I have come out to this 3 times now. Electrical gremlins maybe?
moonie
NC
I've found that if my fob is in my pocket I'll accidentally setoff the alarms on either of our cars, even been known to put down the windows on my wifes previous car during a snow storm... It could be due to a pair of jeans that were a little to tight, obviously the washer's fault...
brucelinc
Ben, if the unlock button is not being accidentally pressed, you might want to remove the battery from the fob you are using and begin using the other fob that came with the car.
By the way, I look forward to seeing you at Brainerd again....or meeting up at a stoplight like we did before. I think the results might be different next time. LOL. Of course, if you have added meth, I might be sorry I have challenged you!
TomahawkSHO
Amazon has these silicon key fob covers that have basically eliminated my accidents with setting the car alarm off when I kneel or bend over. They've got a few colors, too. I was tired of the chrome finished accents on the fob looking like **** from dangling off my keychain every day. All the buttons are just as easy to push (on purpose) like they were before
Johnbigdog
michigain
The featue is called global open. Some Ford have open and close. If you press the button again while moving the opening will stop.
Gbczyk84
At least on my 13, there is a on/off selection for this in the vehicle settings, left of steering wheel.
Johnbigdog
michigain
17 bud. nope nothing.
Yep. It' there I'm sure. Might be turned off in the cluster as noted above?
Owners manual page 79. Says unlock the car, then press and hold the button. The Aceasoey delay relay can't be active. So if you just shut off the car, the system won't work.
