Ambient lights
95ShoOff
Is there anyay to change the color of the light when doors open. On my gfs 17 explorer when she turns the car off and opens the door the ambient lights change from what color she picked to red.
SHOinVa
Tidewater Va
It depends - what year is your car?
As per rubydist my 2012 as a button next too the rear sunscreen button that will cycle through all kinds of colors, you can even have lights on in the cabin while driving or completely off. I have no idea what years this was available or if its an option or standard, only that my 2012 has it. Hope that helps.
Charlie
bpd1151
Lurking Around
SHOcago 'Burbs
Although there is a button hidden under the slim, rectangular door located in front of the gear selector, that allows one to toggle through both the various colors, as well as degrees of brightness.....
The color typically defaults to a light blue upon opening any of the four doors. At least on '10-'12 model years.
Not sure on 13's and up, if the default color is a programmable option, or not.
EcoBoostSHO
On the 13 SHO there is a menu item in Sync...they got rid of the physical button.
Sent from my XT1650 using Tapatalk
bpd1151
Lurking Around
SHOcago 'Burbs
Ok, well that's one part.
The OP is asking if that color can be changed? He states it turns red upon opening a door.
2nd part would entail answering that. Is that a programmable feature? Changing the default color upon opening the doors?
EcoBoostSHO
Gotcha. Well on my 13 it defaults to blue...then it turns red when I start it which is what I set it to in the menu. I see no option to change the default color on entry. Suppose it could be different on a 17 though...
95ShoOff
Yea thr default color when opening doors on mine is light blue. The sync menu only changes the color while car is in use. My car is a 2017.
OmaHahn
Omaha
Yup, my 2014 is blue when opening door then changes to red as I programmed it in Sync. How many of you lose your programmed color choice though? I can't tell you how many times my red that I programmed stops coming on and it's the 'default,' blue. I then have to change it back to red in Sync. This has happened enough times to p1ss me off!
Lostneye
NY
Yes mine does that too
Magna
Yup blue when entering and green as set colour.
95ShoOff
Got another question, i was thinking about buying anothet oem ambient kit and add them behind the air vents. Would all i have to tie light the wires into the preious lights?
Jeff2017
My 2015 does not do that.
TDS-MN
Minneapolis, MN
My '14 does this fairly often as well. Have not figured out the trigger for the rest, I had been thinking that maybe it was when I remote-started the car, but that hasn't proven to be the case all of the time. Annoying, but easy enough to reset, I suppose.
Staff online
