13 +PP SHO rear shocks
Sgtmeatsauce1
2013 SHO +pp
New Jersey
I just got new front struts, MC PP struts for 2013, sag on springs are fine, 61,000 on the car's OEM suspension. Looking at rear shock replacement, not many options for the +PP 2013 SHO. So, choice to match the MC front struts?... just get MC PP rear shocks or these HD for Police Interceptor, which look meaty and accompaning description reads really nice. Anyone have opinions or past experience?
MONROE 550058 - Gas-Magnum Severe Service
Rear; w/ Police Package
The Monroe® Gas-Magnum® truck shock absorber is designed for mid to full size, hard working pick-up trucks and vans. These units provide firm control without a harsh ride. With up to twice the fluid capacity of standard 1" bore shocks, Monroe Gas-Magnum truck shocks work more efficiently with less effort.
Features
All Weather Fluid: Contains special modifiers to reduce friction and ensure smooth rod reaction.
Full Displaced Valving: Better valving range on both the compression and extension cycles of the unit for a smooth comfortable ride.
Sintered Iron Piston: Stronger than traditional metals, enhances durability for long service life.
Nitrogen Gas Charged: For improved ride and handling, helps maintain tire to road contact by reducing aeration.
2" Reserve Tube: More fluid for more consistent performance.
1-3/8" Bore: Lower operating pressure than standard 1" bore units.
Special Seal: Self-lubricating fluid seal designed to retain gas without excessive wear or friction.
beequick
Those Monroe’s are very likely what I’ll be using when I change out the struts and shocks
SHOinVa
Tidewater Va
- I was wondering what kind of struts you used, I will be honest I don't know what "MC PP" are, this is a pretty hot topic that comes up often so I am wondering what you end up putting on the rear, Keep us posted.
C/
SHOinVa
Tidewater Va
Yes sorry, Motorcrap Performance Package. .
GOT IT! Yea I think we have the only car in America no one makes a decent set of performance shocks for, (except for coil overs). I keep hoping I will run across a crazy cool hack, like no one knew before the shocks for this car also fit a Taurus, Keep us posted.
C/
Sgtmeatsauce1
2013 SHO +pp
New Jersey
ZSHO recommended I stay with the Motorcraft PP shocks to match my MC PP struts. Currently I will probably take his recommendation unless something changes my mind. I do carry alot of weight in trunk, including loads of firewood so I was thinking the HD meaty shocks might be good. I just don't want a weird mismatched suspension issue since I would have to live with it.....everything for me is a cost vs ? Option...
Gbczyk84
Could you guys confirm the part numbers for the PP shocks and struts? Just started a new post because my part numbers are not showing any results.
Sgtmeatsauce1
2013 SHO +pp
New Jersey
From ZSHO ecoboost performance list....
The Motorcraft front Struts can be found below for my 13 PP-SHO. Z
MOTORCRAFT AST12321 {#AST12256, DG1Z18124U} Front Left; w/ Black Calipers; w/o Painted Calipers
$54.79
MOTORCRAFT AST12323 {#AST12257, DG1Z18124W} Front Right; w/ Black Calipers; w/o Painted Calipers
$54.79
Grand Total $113.09 which includes shipping for the Struts.
(http://www.rockauto.com/en/catalog/...v6+turbocharged,1503823,suspension,strut,7584)
#&$@ REAR SHOCKS PART NUMBERS BELOW
13+PP SHO X2 same part number DG1Z18125F
http://www.rockauto.com has the best price of $135.89 with promo-code applied and shipping included.
13+NON-PP X2 same part number. DG1Z18125C
$133.89
http://www.rockauto.com $65.79
https://parts.levittownfordparts.com-$76.16
http://www.fordparts.com- $120.42
http://www.rockauto.com/en/catalog/...harged,1503823,suspension,shock+absorber,7556
