Down pipes?
OmaHahn
Omaha
Yours just arrived today, shipping is frantically scrambling to get all the back ordered ones out. THEN we can fill any new orders. *wink wink, nudge nudge*
My pocket book needs A LOT more than flirting to be an easy date and "open up!" ;) Any specials, 50% off and free shipping to celebrate National Arbor Day??!!
mybigsho
new york
Installed the DP'S after work today.. Took a nice ride home, getting on it a couple times.. Feels good.. There
was a nice open hwy. got it up to 135.. I will see if it picks up in the 1/4 soon..
Kphoenix07
I know this may not be approved by most...but felt i would throw this info in this thread. Not that there is a question asking for it. But what the ****...
*use a spark plug defouler on ur test pipe(s) to keep the cel light at bay.
*have had to make exhaust gaskets on the fly before...tin foil folded about 10 times pressed n cut to fit works ok.
...old ricer day tricks. Obviously the real gaskets and using your cats are the best options. I just felt like sharing. Lol
StealBlueSho
NA
The defoulers from what I understand don't work on our platform...
mybigsho
new york
So I got to the track Saturday with the new tune and DP'S.. As I said it felt better, more mid range and pulled
a little harder.. I did not beat my low et of 12.90 at 106.50 in mine shaft November air.. It ran a
[email protected] [email protected] [email protected] [email protected] [email protected] [email protected] [email protected]
In 100% humidity 65 deg. cloudy with interment showers.. The track was not good.. All in all it picked
up 3mph and runs 12.90's in ****** air.. I'M HAPPY!!! I also went over the scales 4565..W/driver..
TXPony
I just installed my Catless DP's I got from LMS. Paired with the CAI, 3bar map sensor, and tune I got through them, I have to say I'm more than impressed. I don't have any numbers, but I can honestly say it's a totally different car now.
reward44
Western NC
Interesting to here the results. I've been debating on downpipes for awhile but haven't seen much results from just downpipes install alone.
Ahrmadillo
Wisconsin
youll get a better result from just downpipes catted or not over stock and better result than doing a catback exhaust. the factory dp are so restrictive its not even funny. your turbos will be able to spool up quicker and breathe better
TXPony
I agree, I think they made almost if not more of a difference than the tune itself, and hearing them spool up is a joy to the ears as well!
Ahrmadillo
Wisconsin
exactly lol the benefit of being able to allow your turbos to spool up anywhere ive seen 200-500 rpm quicker and ive seen performance gains of 20-40ish hp and gains of torque the same worth the money
SHOinVa
Tidewater Va
So for various reasons it has taken me little while to join your little "Down Pipe club" but I finally got mine ordered today. I went in a slightly different direction then most of you, I went with the PPE with cats pipes. I accept my flow numbers may not be as good but they meet my needs. I did get mine ceramic coated Glacier Silver, so they wont be polished but maybe I won't burn my Dads grass anymore when I park in the back yard. Going to take awhile to get them but I will let you know how things turn out.
C/
So you are creating more work for your dad then :) Literally no diff between catted/uncatted in real power terms, so you made a good call!
SHOinVa
Tidewater Va
LOL My Dad does love his grass, its just two spots you can actually see the outline of the cats. The PPE pipes do flow a little less then other pipes but you don't get any codes and if you want you can run a stock tune. Its just my road trip car so the small difference in flow really will not effect me at all. Besides I like being different.
C/
gimpy
Pennsylvania
I'm guessing this with the LMS tune, CAI, tstat and downpipes?
Which tune file are you running and octane rating? Did you install the 3bar yet?
...questions
Jeff2017
I have been tossing around the idea of installing down pipes on my 2016 sho.. The questions I have
can I run with stock exhaust back and are the gains worth the price.. I see they say 15 to 20 hp.. Any
real info on your gains would be appreciated... I am tuned by lms and its a non pp..
Thanks..
Will less restrictive down pipes void the warranty?
