O2 sensors
Boosted Sho
Has anyone came across a problem where the o2 stops reading? I been chasing a hesitation and the cars runs great and then it starts hesitating and af ratio stops reading. And lambda also don't read if I turn the car off they start reading again. Help would be greatly appreciated
No codes set? No lambda on either bank?Sounds like a battery issue, an o2 connector issue, maybe even a pcm issue.
Boosted Sho
Thanks I got a po130 po150. Ups it be the meth?
Boosted Sho
Thanks I got a po130 po150. could it be the meth?
I didn't check bank 2 . But I had a leak at the dp that has been resolved. Cars pushing 100k got 1 new sensor wanted to replace all of them.
Ima going to go back to a revision before the meth and log
Boosted Sho
No problems after taking the meth out of the equation
Boosted Sho
so possibly an issue with the controller?
Well here's where I'm @ on this. no meth no problem. As soon as the cars at highway I'm going test the meth on my e20 tune and see if the sensors don't stop. I have 1 new sensor but the wires are short so Ima solder and shrink wrap them and replace the bank 1 sensor. Go for a ride and introduce the meth and see if they both go or just the back sensor. That has 94k of miles. I'll let u know. As for the meth controller it's operating as commanded. But what could basically short out my sensors? Until I spray a lot of meth 625ml 100%pure meth and e20. Car will **** a three qt tank in two or 3 good wot to triple digits.
jtreber
Indiana
Whoa, that’s a lot of meth. Granted I’m an easy driver on my DD the majority of the time and I have the alky control 100% meth system which I believe has a variable control. But I don’t use 3 quarts in 2000 miles of daily and a couple ¼ mile runs. Maybe mine is set up more conservatively.
Boosted Sho
It seems to drink it I have a 3 qt tank and carry a gallon when I go out. Couple good roll races 3 or 4 hits "in Mexico" I better check the tank usually low level will start to flash. Other than that I don't use any. I'll go threw about a gallon if I go out to hurt feelings 3 to 5 kills
SilverSH0
I don't have my meth hooked up yet but that seems like a TON to go through. Going through a 1/4 gallon of meth per run seems like an awful lot. That's 1/4 gallon in 20ish seconds or less. Even my ski boat at WOT doesn't go through that much gas and it has a solid stream of gas at WOT. I would maybe message BPT about the meth consumption because that seems excessive to me and that might be part of the problem.
