Meth wiring question
Corey Sig
2011 SHO PP
MD
Where did everyone hook up their power source for their meth kits? I keep blowing fuses and need a good spot. Thanks.
Corey Sig
2011 SHO PP
MD
I figured it out actually. I was using a 5. But went to a 10 and it worked. Didnt blow.
SilverSH0
So you changed the stock fuse from a 5 amp to 10 amp? That's not a good way to do an install. Now your stock electrical system is no longer protected with the proper fuse (5 amp) and has the potential to fry things. There is a device called an add-a-fuse that will allow you to maintain the stock 5 amp fuse and add a separate fuse properly sized for whatever wire you're adding. Changing a 5A fuse to a 10A fuse isn't the best way to do things.
But if you're saying you changed from wiring to a stock 5A circuit and wired to a stock 10A circuit that's different. Simply trying to make sure you didn't simply change the fuse sizes (I've seen that done a lot).
