Top Tier Gasoline
subframe
New Hanpshire
I didn't see Sunoco on the list... That's one of the more popular here in New Hampshire and is what I use. Now I'm worried!!!! I run a 93 tune!!!......Rich
Wouldn't worry too much about it as long as it's a high-turnover station, and your car is running fine. If you wanted, run Techron every 1,000 to 3,000 miles in the gas tank to keep fuel-contact areas clean.
subframe
New Hanpshire
Is Amsoil PI the same thing as Techron?. Sunoco supplies all the fuel to NASCAR so you would think that it would be on the top tier list.....Rich
Pump gas doesn't play by the same rules as racegas ... You can try the Amsoil PI instead. I have no idea how well that works though. Plenty of "testimonials" for it tho.
Same here. I also live in the Northeast and most stations are Sunoco. There's a Mobil a little further away, and that's where I get my gas. I had the BG fuel induction service done a while ago, and I want to keep everything running clean. :)
2011TAURUSSEL
2014 SHO LMS Stage 1 V10
DFW Metroplex, USA
I had the same problem with my trip to PA for the Ford Nationals, common station is Sunoco but Mobil should be since they are part of Exxon. If you have the Gas Buddy App there is a selection to select ("By Top Tier") If you have to choose between getting 93 and Top Tier TAKE the 93.....Trust me ask me how I know. Don't sacrifice a chance to get 93 looking for Top Tier. A tank or two NON TOP TIER wont hurt as much as sacrificing 93...especially if you have a 93 Tune. I personally have a laminated card of the Top Tier stations that I keep onboard at very minimum the retailers in my region or potential road trip destinations.
