lubes
Sgtmeatsauce1
2013 SHO +pp
New Jersey
2013 pp SHO, I am looking to replace the rear differential fluid wanted recommendations and if it requires friction modifiers added, if so which part number. My 35,500 mile car is currently getting a new PTU so that should be good for a year or two. I will take car to my repair guy who will flush and fill trans. He only uses synthetic but is there a recommendation for synthetic trans fluid too? Thanks for all replys.
If you have the trans fluid changed regularly, as in yearly, you can use the Motorcraft Mercon LV, that's what bpd uses. Another choice is Amsoil Signature. Haven't heard of how the Valvoline MaxLife works, but that is an option. BG Flush uses BF fluid, that is good as well. No friction modifiers.
None needed in trans, PTU or RDU. Start with good quality fluid, that is enough.
Sgtmeatsauce1
2013 SHO +pp
New Jersey
OK cool, used to locking diff in G8, had special 69 dollar **** with special friction modifier made with amino acids and other weird stuff. Dealer called may get my car back tonight, with new PTU. Will do the other two asap.....thanks
Sgtmeatsauce1
2013 SHO +pp
New Jersey
Perfect thank you! My car manual in my car at dealer. My manual lists my 2013 pp as having sp528 plugs.....? I guess I got an early build before change over to sp534.
Also mine says 5w-30 oil, Dot 4 LV only brake fluid (PP car), Orange coolant, trans says use ONLY Mercon LV trans fluid, and what the **** is blinker fluid, synthetic type bf?
  1. SHOs do not have hydraulic power steering, so Power Steering Fluid should be "Does Not Apply" or something like that.
  2. Engine oil was 5W20 for 2010 only, changed to 5W30 in 2o11. Best to follow what the label on the oil fill cap specifies.
  3. Specialty Green & Orange coolants are not interchangeable. Must use what the car came with, if all else fails, use a universal that specs for both. In 2013, the Specialty Green was dropped, and Orange became the standard in the Taurus lineup.
  4. Refrigerant is R134A: YN-19 (US), CYN16–R (Canada) WSH-M17B19–A
  5. Refrigerant Oil is simply PAG oil: YN-12–D, WSH-M1C231–B
  6. Trans fluid spec should be XT-10-QLV
Thanks for compiling this list, Devin, great reference!
Interesting! What is the build date on your SHO? would need VIN to confirm on ETIS.
This is what ETIS is showing (http://www.etis.ford.com) - Build date is March 28, 2012. Weird for a 2013 MY SHO ... Would explain the SP528's tho.
Missing
* Illustration shows model only
Taurus, 3.5L DOHC V6 Petrol T/C, Tuxedo Black Metallic
VIN Number: 1FAHP2KT3DG111212
Primary Features
Build Date: 28.03.2012
Vehicle Line: Taurus
Body Style: 4 Door Saloon
Version: SHO
Engine: 3.5L DOHC V6 Petrol T/C
Transmission: 6 Speed Auto Transmission 6F55
Drive: LHD 4WD (FTD)
Axle Ratio: 3.16
Emission: With California/Green State Req
Air Conditioning: Dual Zone Auto Temp Control A/C
Territory: (+)"USA"
Paint: Tuxedo Black Metallic
NavPanelArrowCloseDown 18x18
Minor Features
  • Charcoal Black Interior
  • With Wrapped "B" Pillar Trim
  • Rear End Fascia - Level 2
  • Fr Dr Scuff Plate - Met Insert
  • Less Body Armour
  • With Front Fascia-Level 3
  • With Performance Front Fenders
  • Driver & Passenger Seat Map Pockets
  • With Heated/Cooled Front Seats Only
  • Less Centre Console Top Finisher
  • My Key
  • SHO Package 1
  • Chicago Plant Build
  • Less Appearance Group
  • With Memory Pack
  • Feature Content Group 1
  • Less Paint Package
  • 2013 Job #1 Program Control
  • With English Language Label
  • Owner Hand Book Pack
  • Less Mass Customization Package
  • "A" Pillar Cloth Trim
  • "C" Pillar Cloth Trim
  • Power Front Wndow-1 Tch Up/Dwn-Pass
  • With Electric Rear Windows
  • With Solar Tinted Glass
  • With Front Side Laminated Glass
  • With Aluminium Instrument Panel
  • Standard Ovrhed Console & With Rail
  • With Full Floor Console
  • Less Rear Floor Console
  • Memory Adjustable Foot Pedals
  • Front Throw In Mats With Logo No.2
  • Rear Floor Carpet Mats
  • With Carpet Floor Covering
  • With Illuminated Sunvisor - Drivers
  • With Illuminated Sunvisor-Passenger
  • Door Trim Panel Insert-Film 2
  • Grab Handle Side Door - Plastic
  • With Power Rear Sunblind
  • Trim Rear - High Line
  • With Load Retention Net
  • Spare Wheel Stowage Cover
  • Grille - A-Gloss
  • Less Active Grilleshutter
  • Bright Greenhouse DLO Moulding
  • With Single Rear Wing Spoiler
  • Inside Mirror With Auto Wipe Sensor
  • 4 Door Saloon
  • Dual Pwr/Htd/Fld/E'Chro/Pudd Lamp
  • Ext Mirror Finish-A Gloss Skull Cap
  • Less Rear Sliding Seat
  • With Rear Center Head Restraint
  • With Heated Rear Seats
  • 2nd Row Seat 60/40 (3 P) - Folding
  • Less 3rd Row Rear Seat
  • With Driver 8 Way Pwr.Seat Adjuster
  • With Pass 8 Way Power Seat Adjuster
  • With Programmable Driver Seat
  • Less Interceptor Siren/Speaker
  • Less Special Service Vehicles 1
  • Less Special Service Vehicles 2
  • Less Special Service Vehicles 3
  • Less Special Service Vehicles 4
  • Less Engine Oil Cooler
  • Body Coloured Exterior Door Handle
  • With Leather Gear Shift ****
  • Less Decklid Pulldown
  • Less Keyed Alike Options
  • Frequency - 315MHZ
  • With Central Locking System
  • Keyless Entry/Start - Passive
  • Rain Sensitive Windshield Wipers
  • With Tilt & Slide Sunroof
  • Less Tu-Tone Accent Colour
  • With Front Licence Plate Bracket
  • Side Air Bag - 1st & 2nd row
  • Rear Seat Belts - 2nd Row
  • Less Spare Wheel
  • 20" X 8 Cast Alum - Premium Paint
  • 245/45R20 Y-Rated
  • Less Spare Tyre
  • Less Wheel Covers
  • Less Immersion Heater
  • With Remote Starter
  • With California/Green State Req
  • With Standard Suspension
  • 3.16
  • 3.5L DOHC V6 Petrol T/C
  • Dual Exhaust
  • With Dual Chrome Exhaust Extension
  • Power 4-Wheel Disc Vacuum Boost
  • Brake Calipers - Black
  • With Anti Lock Brakes And ESP+
  • Normal Fuel Fill
  • All Weather Floor Mats - FIA
  • Less Transmission Oil Cooler
  • Floor Shift
  • Select Shift Tech (SST) W/Pad Shift
  • Non Locking Capless Fuel Fill
  • For Unleaded Fuel
  • Unique Met Finish Foot Pedals Pads
  • With Electric Power Steering
  • Power Tilt/Telescopic Strg Column
  • Less Steering Column Lock
  • Leather Steering Wheel With Accent
  • With Heated Steering Wheel
  • With Speed Control
  • Redundant Controls-Steering Wheel 2
  • With MPH/KMH Speedometer
  • With Tyre Inflation Kit
  • With Header Mnt Compass/Thermometer
  • With Nav System-Becker Traffic Pro
  • Less Lane Departure Warning System
  • With Blind Spot Monitoring
  • Human Machine Interface 4
  • With Perimeter Anti-Theft
  • With Rear Parking Aid
  • Less Front Parking Aid
  • With Automated Parking System
  • Medium Duty Battery
  • Heavy Duty Alternator
  • With Region 1 Electronic Equipment
  • AM/FM CD/Clock
  • With Satellite Radio Reception
  • With NAAO Radio Frequency
  • HD Radio Broadcast
  • With Level 2 Sound System
  • Less Radio Suppression
  • Sync II
  • With Universal Garage Door Opener
  • Less Wiring Prep
  • Rear View Camera-Fixed
  • Less Fog Lamp Bezel
  • With Auxillary Lights
  • High Intensity Discharge Headlamp
  • Less Daytime Running Lamps
  • Less Front Fog Lamps
  • Less Spot Light
  • Less Right Hand Spot Light
  • With Ambient Lighting-Interior
  • (-) Package Ty/Dk Lid Lamp-Pre Wire
  • Tail lamps - Level 1
  • With Auto High Lamp Headlamp
  • Less Power Distribution Box - Front
  • Tuxedo Black Metallic
  • Generic Country Group 1
  • 6 Speed Auto Transmission 6F55
  • Taurus
  • SHO
  • (-) GVMT Service Administration
  • (-)"CDN"
  • (-)"GU"
  • (-)"BRN"
  • (-)"BZ"
  • (-)"ATG"
  • (-)"KOR"
  • (-)"AW"
Sgtmeatsauce1
2013 SHO +pp
New Jersey
Interesting, I am suppose to have 2013 PP, But says
  • Standard suspension
  • Less Engine Oil cooler
    • And no stinking body amour
Sgtmeatsauce1
2013 SHO +pp
New Jersey
My calipers are just metal color.......no mention of PTU cooler......I hope I do actually have the coolers, that whole reason I got the PP! I also don't have leather steering wheel, it's alcatrana(?)....but I do have high performance front fenders and high gloss skull cap!
Devin
3.Slow
Pacific Northwest
Fixed.
Sgtmeatsauce1
2013 SHO +pp
New Jersey
Thank you for your continued efforts, sorry to be pain in ass. My car has the old plugs but new, orange radiator fluid, Dot 4 brake fluid (car is a PP).......Thanks again.
Also please note ALL years Blinker fluid has been updated to a Silicone based fluid and IS backward compatible for all years from 96 to current. Just saying....
