Paint rub question.
Pintony
40 miles N.E. of St; Louis
Hello SHO Forum,
My 014 trunk lid is rubbing the bumper cover in the rh & lh corners.
There seems to be plenty of gap.
Why or how could this be happening?
I tried to take photo but could not get a good one.
Gbczyk84
I noticed the same on mine, I think when you close the lid it hits.
Flylow11
Nashville TN
Ok cool. The build quality on the SHO's seem very good. I was thinking maybe the trunk hinges might have gotten out of alignment.
Pintony
Thanks again BlueSHO Went out and adjusted the bump stops. That should stop the chafing.
Just turn the bumpers to adjust.
I see a Few Taurus 013-up at night that could use this to even out the taillight alignment.
I never thought to look for the bump stops on the trunk lid itself.
BlueSHO
Awesome. We are all here to help each other
Sent from my DROID RAZR HD using Tapatalk
cfgibmc
Looked at my 14 and saw a rub mark on the bumper after a fast run. Suspect the spoiler down force is collapsing the rubber seal at speed. Bump stops adjusted too high.
Sent from my HTC6535LVW using Tapatalk
Pintony
Hopefully you got it before rub through clear coat???
cfgibmc
It should buff out. Thanks.
Greg Winokur01
My 2010 had the same problem, bumper stops didn't help much.
365SHO
2014 SHO NON PP I put door guards on all my doors. the drivers door gap was tighter than the others so I had to remove the door guard. GAP difference there as well
