Bryan
What do you get when a deer & SHO cross at 45mph?
Okay... So my DIS module may be going on me... The question now is which one should I replace it with? Ford shows they have the original part at $320. SHOSource also seems to stock it as well at $250 (brand not listed, though stated as high quality). Also I checked AutoZone and they stock the same part (Duralast) at $131. NAPA Auto Parts also lists it (Echlin Ignition) at $177. And finally Advanced Auto shows two different ones. BWD Ignition, or Wells Vehicle Electronics at 135 (BWD) or 175 (Wells) respectively.
Also what kind of thermal paste should I use? I have some from when I built my PC and had to apply some to the CPU heat sink. Would that work well enough? And how much is a good amount? Just make sure to cover its entire base right?
That and a new EATC as well.
