Moonroof issues - Click but no movement
eacyde
Pinkley Taurus
Calgary, Alberta, Canada
I purchased a 95 ATX Turd to drive around in while my other SHO gets fixed.
When I hit the switch, nothing happened so I pulled the cover and discovered the wires to the motor were all over the place and disconnected.
I had a good motor so I swapped it in. When I hit the switch, I hear the relay click for both directions, but the moonroof still doesn't move.
Where do I go from here? It is not closed properly and it is leaking into the back seat.
mrecoolgar
SHO NUP
Hershey-PA
Bad motor?
The switch is activating the relay.
The relay sends power to the motor.
Remove the console, then the motor.
Rotate gear manually to close.
eacyde
Pinkley Taurus
The motor is good. At least it was when I removed it.
Does anybody know what fuse powers it? The list in the owners manual doesn't have Moonroof.
eacyde
Pinkley Taurus
