Acid Ported Intake today.....
zak
east of Hartford
i did a bit of acid porting before...
i did a 5 to 1 mix 15 times for the short and long runners.
granted it wasent smooth as extrude hone but it removed much more material then EH does and its a lot cheaper then EH
Thanks. Can you measure the inlet and outlet diameters on your short runners? I have some detailed measuremnts on extrude hone runners somewhere around here for comparison.
Which acid did you use?
gmail
Well-Known Member
sunbury pa
muriatic acid... i lost the intake in my move so i cant measure it sorry... if i find them ill do a fluid test for the over all volume
