which o2 sensors? 3.2 MTX
zak
east of Hartford
The 3.2 ATX O2 sensors use a 4 wire, the fourth wire serves as a ground connnecting the sensor direct back to the ECM.
The 3.0 L MTX setup uses a 3 wire sensor so that is what will bolt in. However, considering that the ground path is through the rusty cast iron manifold, through the aluminum head, then into the cast iron block and then to the ground strap, you might consider using the 4 wire senors and just running a ground wire to the ECM/EEC-IV. The higher voltage signal received should cuase the ECM to lean things out a bit and improve fuel mileage.
Probably more than you wanted to know . . . .
Phoenix
SHOHOLIC
QC , Canada
TheMoreYouKnow
SHOclass
Conan has one
S. Windsor, Connecticut
haha, well I already put the 3.0 sensors in. whatever its not my daily driver.
Also thanks for the fast response chris, I was standing in front of my old boss at NAPA and had a brain fart when he asked me.
