jayro
Hi all,
I wanted to make sure I got this right. I want to bleed my whole brake system including making sure there is no air in the master cylinder. I was searching and found some posts suggesting I jack the front of the car up as high as I can get it and then bleed the snot out of the system at the calipers. They said that this will push any air that may be in the MC through the lines and out of the calipers. Will this method work? Also (kind of a stupid question) with the front jacked up and the rear on the ground I will only be able to bleed through the front, will this still get any air out of the MC? I saw I should run about 2 quarts through it to make sure.
My brakes work pretty well, but the pedal feels a little soft under hard braking. It has good resistance at first, but then gets gets softer under constant pressure. I already have SS lines and the '96 uprade. Thanks
