Transmission questions
19FoSho92
Massachusetts
I blew the diff out of my sho this week and i have another transmission to swap in but its from a gen 1 is there any difference between the transmissions besides the cable setup and what transmission fluid should i put in it. i got a new clutch and new axle seals ready to put in it also
jayro
Auburn, In
Trans is the same. As far as fluid, it depends on the trans. Of course they all take ATF, but what works best varies from unit to unit. People have had good luck with Mobil 1, Synchromesh, Valvoline MaxLife, Redline, Royal Purple etc. I would suggest installing a drain plug before you put it in the car. That way it will be easy to service.
chrism3784
West Palm Beach, Florida
Get the diff welded. If you don't, what happened before will happen again! Take to tranny shop have to disassemble it to the diff, and mail it off to someone on here and get it welded right. They mail it back, give to tranny shop and have it put it back together. Also tell them if they spot any problem inside or bad pieces, you can have anyone like me with 2 disassembled complete transmission parts spare you whatever you need. I went through 2 trannys before I got smart and got it welded! Don't make my mistake. They diff pins can blow at any time, any place.
As far as anything else, no difference at all, just to two brackets are different and interchangable.
shobote
Naperville, IL
It is easy to do burnouts with the MTX open diff, since one wheel is spinning while other other isn't, and that is what causes diff pin failure. If you want to save time and are short on money, there is no need to have it welded, and you wont blow the diff pin if you don't do one wheel burnouts.
19FoSho92
Massachusetts
i could weld the diff myself i work at a performance shop, my transmission blew when i downshifted to turn haha but where would i put a drain plug? and i'm just trying to get the car done so i'm going to just get it in the shop this weekend when were closed. I was just a little scared because i ordered new axle seals for a 92 and they sent the wrong seals and then i asked about an 89 and they got me the right ones
AREA 91
Area 91
Weld the new diff before you install it.
I also recomend a drain plug.
kevinspann
Don't take my advice.
Richmond VA
The axle seals should have been the same, they just did it wrong.
The earlier trans will have different, brass synchros in it. That's about the only difference.
19FoSho92
Massachusetts
thanks for the write up, how hard is it to get the diff out of the transmission and is there any walk throughs on how to take the transmission apart?
kevinspann
Richmond VA
You have to take the whole thing apart. There is a writeup on this site, and shophoenix.com, but the factory service manual is best, because it also shows you how to put it back together.
19FoSho92
Massachusetts
just as an update i did the job drove it it seems great, i looked up a few pictures on here and i welded the diff pins and i also cut the shifter down a little bit to make a short throw, the car shifts better than ever :) thanks for all the help
AREA 91
Area 91
Great to hear. Now, just because your diff is welded, dosen't mean yu should do burnouts!!!
:wave:
19FoSho92
Massachusetts
yeah i've only done real burnouts with the thing one night, it's my daily driver so i try to control myself on the pedal as much as i can haha, i just like seeing peoples faces when they see a taurus fly by them and they don't know whats goin on
Staff online
