Name that plug
t5535
Sioux Falls, South Dakota
I know allot of you are very smart on these cars. I fugured if anyone cound answer this it would be you guys. you guys have been ALLOT of help already!!! I just got done installing the motor and trans (subframe). I have 2 plugs that I can not figure out what plugs into them or where they go.
this one is down by the rack.
This one is up by firewall on drivers side.
Any help PLEASE!!!!!!
operdot
USA
Can't see the pictures for the last two but the first one is for the VAPS (variable assist power steering) it can be left disconnected, however you won't have super smooth power steering at low speeds.
I actually prefer my steering without VAPS.
t5535
I was having trouble getting pictures on here. Im a first timer lol. you should be able to see them now. What plugs into that VAPS and where is the wire?
hawkeye18
Sorta cares
Norfolk, VA
Have no idea what the first two are, but the last two are for the VAPS test connector. It's not supposed to be connected to anything - no worries.
trainguy1989
SHOtarted
Wichita, Ks
I think the first one is the power steering pressure switch. The second one is either VAPS test connector or the plug for the under hood light if equipped.
hawkeye18
Sorta cares
Norfolk, VA
The underhood light connector is much larger than the VAPS test port. It is definitely the latter.
