Name that hoes!
SHOtimer
#2910
Santa Clarita, Ca
I assume you mean hose?
At first I thought this may be a NSFW thread!
That's a vent hose to the charcoal canister inside the fender well. It vents the gasoline fumes out of the intake system through to the charcoal canister.
Are you getting a fuel smell? I would replace it...with PCV/EGR hose. Autoparts stores usually sell hoses just for that purpose.
Doug
SHORANGERBIRD
Restorer of SHO
Alexandria, Alabama
Doug
-yep. that is the one. runs up the core support, out behind the headlamp, and over to the charcol cannister behind the fender.....
Off Road SHO
Moderator
Vents the fumes out of the intake and into the charcoal cannister?????
I could be on crack like the rest of the responders to this thread, but doesn't the gas tank vent to the charcoal cannister, which is then purged of its fumes when the cannister purge valve is opened every once in a while by the PCM? The intake then ingests the fumeous air?
Tom
SHOtimer
#2910
Santa Clarita, Ca
Tom
You're right, I had it bassackwards.
Doug
