delete
SHOmethewayhome
BAD ROLE MODEL
Saint Paul, Minnesota
Your all wrong.
You have two forces in the intake runner while running... one is the air molecule flow it self and another is a pressure wave front that travels at the speed of sound. If you notice the horns are set at right angles to the plenum wall with little clearance. The bell mouth allows for smooth air flow during the intake stroke but during overlap the air flow is reversed. The pressure wave travels back up the port faster then the air flow, smacks the wall and reverberates back into the port, prevent air flow from reintering the plenum. It acts as a check valve.
I like this answer.
I'd like it even better if you send me a case of that delicious pumpkin beer you guys make come october.
NovaSS
Project MINIGUN
Thats why SHO get louder when you remove the horns, this pressure wave is no longer trapped in the intake runner and enters the plenum
http://www.downingbrothers.com/supercharger/tuned-intake-runners.htm
I would bet the aiflow you gain from BBBs is off set from the loss of tunning when you get rid of the air horns
NovaSS
Project MINIGUN
Punkin is easier to get then 120 IPA right now, Im having a hard time getting even a 4 pack of the stuff and I work there !
zach44102
BIG TURBO
Georgia
So would you call them a restriction once you have a ported intake with bbb? or do you think they could still be helpfull?
zak
east of Hartford
Interesting graphic. There was some before/after chassis dyno testing of a stock intake w/ and w/o horns in the SHOtimes era. Removing the horns caused a loss of 1 ft-lb of torque and added 1-2 hp (e.g. within the error limits, so no significant change). On the other hand, properly port matched BBBs (including removing the innermost rubber from the coupler ID) have always shown a 10 hp jump.
NovaSS
Project MINIGUN
Interesting graphic. There was some before/after chassis dyno testing of a stock intake w/ and w/o horns in the SHOtimes era. Removing the horns caused a loss of 1 ft-lb of torque and added 1-2 hp (e.g. within the error limits, so no significance change). On the other hand, properly port matched BBBs (including removing the innermost rubber from the coupler ID) have always shown a 10 hp jump.
I would love to see some numbers of a BBB set up with a set of BB matching horns, I tried this a while back by installing a set of mandrel bent horns in the stock plenum but there was no way to install them with a proper bell mouth.... with out cutting out the side , installing horns and welding it gack up.
100 0909
I had to settled with a simple set of extensions that just got the port out into cleaner air, they are bell mouthed but its hard to see in this pic...
000 0016
Some one needs to build a custom set of tanks with BBB and proper horns and see what the number are.
zak
east of Hartford
Nova, there was a fellow on here that was reverse radiusing the ports in the plenums, to create a better transition into the primary and secondary runners/BBBs.
Nice work on the bellmouths. Maybe some kind of removable plate could be machined into the plenum at the butterfly interface, or maybe study the techniques used to build model boats inside bottles . . . . .
Denny
Taurus Homeland
Atlanta, GA
100 0909
000 0016
What's for dinner?
StreetlightSHO
It'll run eventually...
Phoenix-ish AZ
So if the horns are used to "bounce back" air at the intake valve as it is opening and the length of the runners are tuned so that this wave hits the valve at the right time, then porting your runners would then affect this. Since the CFM in the runners is based on RPM, would porting just change the RPM that this "bounce back" occurs at?
But in the end I'm guessing this barely affects engine performance.
Just trying to get a better understanding of it. :thumb:
SHOmethewayhome
BAD ROLE MODEL
but yes, thanks for once again adding to my longtime belief that chevy fans and small blocks are like retards on ******, they'll jam it into anything no matter how hard it is.
zach44102
BIG TURBO
Georgia
Lets see that v8 festiva take a turn. At least the SHOfestiva is setup to not only go in a straight line.
its the length of the intake runner that impacts the resonance frequency of the air column, not the diameter or smoothness. of course, the diameter and smoothness affect how much air flows through it, but the frequency is due to the length.
